eyes burning - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 12-01-2003, 10:17 AM Thread Starter
eyes burning
Hello all,
I need your input on something. I drive my truck with the windows down,AC off, and vent widows open. My exhaust exits BEHIND the rear tires. It seems when I stop at a light some exhaust fumes are detectable. When I get home from my 30 minute in town drive from work my eyes are burning and sometimes I am light headed. Turning on the ceiling fan and opening a window clears it up within 30 minutes. I am pretty sure the exhaust is not leaking under the bed. The exhaust is assembled with those nice band-clamps and welded at other points. I am running an A9L but I have 36 lb injectors and no custom chip. Plugs look good,no smoke from exhaust,truck runs fine. I do have an adjustable fuel pressure reg but adjusting it seems to make little affect on the fumes. So thats it. All suggestions or ideas welcome.
Thanks,Edward
#9 1995 Lightning
12.5 @ 108 MPH/1.7 60ft
Now 12.7 @105 /1.7 60ft/n/a
New pass!! [email protected] 107.55/1.9 60'
(Goal 12.5 @110 mph n/a)
struckby is offline
post #2 of 5 Old 12-01-2003, 11:10 AM
I assume this is on your '95 L.
What injectors are stock in a '95 L? Is a '95 L mass air? and if so, have you upgraded the mass air meter for the 36lb injectors?
Also check for a bad ground between the engine and the frame. There should also be a ground strap from the EFI harness that attaches to the firewall. That needs to be inplace.
The Fauxstang. Dynacorn 67 fastback. Dart SHP 363, Close ratio Magnum 6 speed, 3.70 Eaton Truetrac in a fabricated full floater 9", SorT coil over suspension. Still in pieces.
J Persons is offline
post #3 of 5 Old 12-01-2003, 12:53 PM Thread Starter
hey John,
thanks for the eliminator,it is working great!!truck is m/a and the meter is recal'd for the 36's.19lbs were stock.
Edward
#9 1995 Lightning
struckby is offline
post #4 of 5 Old 12-01-2003, 03:54 PM Thread Starter
#9 1995 Lightning
struckby is offline
post #5 of 5 Old 12-16-2003, 07:12 PM
Super Moderator
HELMUT RONER's Avatar
Trader Feedback: (23)
I thought the 351W Lightnings use 24 lb. injectors stock.
Helmut
Originally Posted by MFE
HELMUT RONER is offline
