What are the stock cam specs? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 11-28-2003, 06:34 AM Thread Starter
Does anybody know the specs of a stock lightning cam (351w) Also what is the stock compression ratio, I found one sorce saying 8.3 and another saying 8.8 thanks for the help guys!
John
BlkStangerGT is offline
post #2 of 4 Old 12-14-2003, 12:55 AM
The stock compression ratio was/is 8.8:1 The stock cam specs I don't have here offhand, but if you search around the net you can find them
94 Lightning
Kenne-Bell Supercharged
78 Trans Am
400 w/nitrous
gasguzzler is offline
post #3 of 4 Old 12-18-2003, 09:35 PM
Brian Baskin is offline
post #4 of 4 Old 12-19-2003, 06:46 AM Thread Starter
Brian, Thanks alot.... perfect info for what I was looking for, thanks also gasguzzler
94 black on black GT, 351w (.030 over, decked, line bored, balanced) Comp cams 284h cam (284/290,.533/.544), Kenne Bell Blowzilla 2.2L Supercharger w/ 10psi boost, AFR 185's, Cometic Head gaskets (They are the Sh*t!!) Pro-M 77mm MAF, 75mm TB, Mac cold air intake, GT-40 lower intake, 42lb squirters, Walbro 255lph in tank w/ T-Rex external fuel pumps, Anderson Ford PMS, MSD 6AL ignition box, Innovate stand alone wideband air/fuel ratio gauge. FRRP Cobra R swap headers, High flow catted H-pipe, 3 chamber Flowbastards, Tremec 3550 w/ TKO output shaft, Centerforce DF clutch, 373's.
