Setting timing on 1995 Lightning - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 11-17-2003, 11:09 PM Thread Starter
I am helping a friend do a tune up on his 95 lightning.. went to set the timing and was a little confused. The mustang 5.0 has a spout that you have to remove before you adjust the timing.. I couldn't find anything like it on the truck...what gives.. What do I need to know/do to correctly set the timing? Thanks in advance for your responses!
2017 GT350 Triple black stripe delete STOCK
2004 Cobra VertTriple Black, STOCK
65 Fastback A code. Factory A/C car w disc brakes 289 C code
93 Reef Blue coupe...pretty much stock. For now... PARTS ARE ROLLING IN!
ulev1st is offline
post #2 of 2 Old 11-18-2003, 09:07 AM
Mike Gager's Avatar
lightnings have the spout also but its on the drivers side inner fender back by the master cylinder taped up with the EEC test port
Mike Gager is offline
New 351W running! Timing Setting and HP/Torque Estimates? marshal4bob 5.0/5.8 Engine Tech 6 04-10-2015 03:09 AM
Setting timing... MNtony Engine Management Systems 0 11-14-2013 03:50 PM
Timing Chain Cover / Water Pump Bolt Sizes maniac95 94/95 Tech 0 08-15-2013 07:54 PM
idling probelms and stalling, running way rich!!! 92mineralgt 5.0/5.8 Engine Tech 14 12-31-2010 08:56 AM
1995 lightning 87blownstang 93-95 Lightning 10 05-01-2009 05:31 AM
