Anyone changed heads on lightning block? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 11-15-2003, 06:58 AM Thread Starter
Hello, I picked up a 351w SB out of a lightning. Has anyone put diffrent heads on it? I'm looking for a head that won't have interference w/ the pistons. My cam has .480 lift. Thanks everyone
BlkStangerGT is offline
post #2 of 10 Old 11-15-2003, 11:53 PM
AFR-185's work awesome.
cobra1993 is offline
post #3 of 10 Old 11-25-2003, 02:03 AM
I have Edelbrocks (1.90 intake valve) on mine. .520 lift cam, kenne-bell blower.
No problems
John
John Webb is offline
post #4 of 10 Old 12-01-2003, 06:35 AM
I've got AFR 185s with a .512 lift cam
95 Lightning-13.957 at 94.89mph
AFR185s,Comp XE264HR-14 cam,GT40 intake,Pickrel performance Exhaust,Factory tech valvebody,TwEECer RT
Matt95L is offline
post #5 of 10 Old 12-01-2003, 04:22 PM
SVTErik529's Avatar
I am a huge fan of the Trick Flows. My friend put the twisted wedge heads on his lightning with a mild cam(dunno the exact lift).
Erik D.
Married and Mustangless
SVTErik529 is offline
post #6 of 10 Old 12-14-2003, 12:53 AM
When you pull off your stock heads you'll see the pistons have a nice dish to them allowing decent sized valve/cam combos. I haven't switched mine around yet.
94 Lightning
Kenne-Bell Supercharged
78 Trans Am
400 w/nitrous
gasguzzler is offline
post #7 of 10 Old 01-01-2004, 11:03 PM
I ran TFS heads with 1.7 rockers and a E303 cam with no problems
White 94 Lightning
[email protected]
1FASTFORD is offline
post #8 of 10 Old 01-25-2004, 08:10 PM
I've got AFR 185s with a .533 lift cam no problems.
94jeff is offline
post #9 of 10 Old 01-25-2004, 10:05 PM Thread Starter
Thanks for the replies. Are the AFR 185's bolt holes allready 1/2 inch or do they need to be drilled out?
94 black on black GT, 351w (.030 over, decked, line bored, balanced) Comp cams 284h cam (284/290,.533/.544), Kenne Bell Blowzilla 2.2L Supercharger w/ 10psi boost, AFR 185's, Cometic Head gaskets (They are the Sh*t!!) Pro-M 77mm MAF, 75mm TB, Mac cold air intake, GT-40 lower intake, 42lb squirters, Walbro 255lph in tank w/ T-Rex external fuel pumps, Anderson Ford PMS, MSD 6AL ignition box, Innovate stand alone wideband air/fuel ratio gauge. FRRP Cobra R swap headers, High flow catted H-pipe, 3 chamber Flowbastards, Tremec 3550 w/ TKO output shaft, Centerforce DF clutch, 373's.
post #10 of 10 Old 01-25-2004, 10:49 PM
DAVE94LIGHTNING's Avatar
Allready 1/2 inch
1994 Ford Lightning. (357 Vortech YS)
1988 white 5.0 Coupe (100% original)
1991 white 5.0 Coupe (98% original)
DAVE94LIGHTNING is offline
