B-302 Cam - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 10-01-2003, 08:00 PM Thread Starter
B-302 Cam
Anyone ever use this on a SD Lightning, it has a lobe seperation of 116, lift with 1.7s is .512, intake and exhaust are 224*?? Should work huh...
cobra1993 is offline
post #2 of 7 Old 10-02-2003, 01:17 PM
Mike Gager's Avatar
Re: B-302 Cam
kind of high duration
Mike Gager is offline
post #3 of 7 Old 10-07-2003, 08:49 AM
You'll probally need mass air or some sort of engine management to get that cam to work.I beleave cams have to have a lobe seperation of 114 to work with SD.
95 Lightning-13.957 at 94.89mph
AFR185s,Comp XE264HR-14 cam,GT40 intake,Pickrel performance Exhaust,Factory tech valvebody,TwEECer RT
Matt95L is offline
post #4 of 7 Old 10-07-2003, 01:29 PM
SVTErik529's Avatar
I don't think the lobe seperation would be a problem. Like Mike said though, the duration may be a bit high.
SVTErik529 is offline
post #5 of 7 Old 10-10-2003, 07:40 AM
I was told are trucks can't run anything but a lobe seperation of 114* with the stock speed density.Was i misinformed?
Matt95L is offline
post #6 of 7 Old 10-10-2003, 09:22 AM
saleen_n_around's Avatar
Wasn't this the old cam that started the Alphabet cams? This was designed to work with SD Mustangs of 87-88, if I remember right. I'll have to dig out a WAAAYYY old Motorsport catalog to confirm. They don't even sell that cam anymore, do they?
Ron Turransky
NMRA EFI/Ren# 4150
NMRA SSO #8 Crew
Support our sponsors Matukas Motorsports Race Cars, Vincent Performance, Nitrous Express, Vortech, Brodix, Kooks Headers, Holcomb Motorsports, NGK Spark Plugs, PA Transmissions, Pro Power, Racecraft Inc, Total Engine Airflow, UPR Products, VP Fuels & Weld Racing
saleen_n_around is offline
post #7 of 7 Old 10-13-2003, 09:57 PM
Most custom cams use less than 114* of separation. We need at least 114* to get enough vaccuum to operate the S/D system. I would just get a custom grind. Most of those older cams are designed for a much lighter vehicle than our trucks.
94 Lightning
Kenne-Bell Supercharged
78 Trans Am
400 w/nitrous
gasguzzler is offline
