Newbie question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 04-11-2003, 01:18 PM Thread Starter
Newbie question
Sorry if this has been asked before, but I couldn't find it in the archives - how difficult is swapping a 5.0HO Stang motor out for a 5.8 Lightning motor? Will the trans still bolt up? Also, what is the overall difference in heights between the two engines?
Chris
GO 4LO is offline
post #2 of 6 Old 04-11-2003, 07:03 PM
The lightning has a 5.8 in it, and you dont want the lightning trans in a car. The E40D is way too big to fit into a car. If you want to use an AOD or a C4 it will bolt up to the 351.
Basic bright blue bolt on 00 Gt
MnvlMat is offline
post #3 of 6 Old 04-11-2003, 08:03 PM Thread Starter
The motor will be going in a very heavy Jeep. Does the Lightning engine pair up pretty well with a C6 (I'll probably be using some E4OD internals for more torque capacity)? Thanks!
Chris
GO 4LO is offline
post #4 of 6 Old 04-11-2003, 09:26 PM
Any small block ford will bolt up to any small block ford trans.
You could get away with a C$ for that swap.
I dont think anything from an E40D will work in a C6.
MnvlMat is offline
post #5 of 6 Old 04-12-2003, 12:30 AM
From what I understand, the E40D is a slightly (depending on year) beefed up version of the C-6 with an overdrive and is electronically controlled. - Brian
94 Lightning
Kenne-Bell Supercharged
78 Trans Am
400 w/nitrous
gasguzzler is offline
post #6 of 6 Old 04-14-2003, 10:07 AM Thread Starter
Thanks for the replies, guys. The C6/E4OD parts stuff that I was referring to is some sort of conversion by Jet Performance.
How much hp/tq can a stock block/crank/rods/pistons Lightning motor typically handle before blowing up? I'd like to go heads/cam/supercharger and produce as much as I safely can.
Right now, I'm wiring up a stock 5.0HO out of a Stang, but will be building the Lightning motor to drop in this coming winter. The Jeep is going to weight around 6000 lbs, and the tires/wheels that I'll be using are extremely heavy, so I'm trying to build it with as much motor as I can without getting too expensive or too heavy a motor. Thanks!
Chris
GO 4LO is offline
