I need cam suggestions? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 03-07-2003, 08:00 AM Thread Starter
I need suggestions on where i can get a good custom hydraulic roller cam for my truck.I ordered one from cam motion,but canceled because they weren't sure when they were going to get any cores in.I had already waited a few weeks and my engines completely disassembled in my garage and i'm strapped for time i need the truck back on the road by the end of the month if possible.My first thought was Ed curtis,has he done a cam for any of you?Anyways i've sent him an email all ready.I'd like to here other suggestios.My truck has AFRs with 550 lift valve springs and 1.6 stud mount roller rockers.I'm planning on running N/A for now.Is there a good off the shelf cam i should consider.By the way my truck is speed density.
Matt95L is offline
post #2 of 4 Old 03-11-2003, 11:49 PM
cams
Talk to Philip at Performance Works he can make anything you need. Hope this helps. Jeff
94jeff is offline
post #3 of 4 Old 03-13-2003, 03:47 PM
I chose the comp cams extreme cam 266HR (5.0 firing order) for mine. It runs like a bat out of hell up to about 5800RPM and idles smoothly. Trick Flow has some inexpensive off the shelf cams made from very high quality steel billets. There are three that fit a wide range of performance needs and all are under $200 at Summit Racing.
laroux is offline
post #4 of 4 Old 04-07-2003, 03:25 PM
he mentioned he has SD..TFS cams will not work.
they all have lobe centers of 112 or less.
any cam with less than about 114 LC won't work
with SD. the best off the shelf cam is the comp
flat tappet. otherwise go custom grind..
rocket398 is offline
