Harsh shifting lightning - need help! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 02-13-2003, 11:11 AM Thread Starter
My lightning shifts real hard at only part throttle about once every day or two. When it happens, it usually does it for a couple of shifts and then it is fine again. It has been doing this for the last 30-40k miles or so and has 125k total. Any ideas?????
blackdiamond is offline
post #2 of 4 Old 02-13-2003, 01:05 PM
Mike Gager's Avatar
couple things it might be, first there is a solenoid inside the trans that controls line pressure and sometimes it sticks and can cause this. also it could be a bad connection at the EEC computer
before diving into the transmission the first thing to try is to disconnect the computer and then reconnect it, trying to get a better connection. sometimes over time the terminals get some corrosion on them and unpluging and then plugging it back in sometimes cleans the connections and fixes the problem. this seemed to work on my truck as it was doing the exact same thing
anyways inside the engine compartment on the firewall almost directly below the master cylinder you will see the computer. there are 2 actually, one is the wiring connector for the transmission? and the other is the computer. its been awhile since i looked but i think the EEC is on the right (closest to drivers side fender)
simply unbolt the bolt in the center and pull the connector off then reinstall. i didnt even pull mine completely off, just back it out about 1/2" and then put it back in
i went ahead and did both connectors, the EEC and the other one (trans?) took about 5 minutes total
if it still does it after doing this id almost bet its that solenoid. i think its like a $30 part and fairly easy to replace as you dont have to go inside the trans but havent done it for sure
rl on this board i believe changed his, maybe do a search for his name here in this forum
Looking for Fox body Fairmont, Zephyr, Cougar, LTD, Marquis or Granada wagon
Mike Gager is offline
post #3 of 4 Old 02-13-2003, 05:21 PM
I used to have a computer chip that messed my shifting up too, but now I've got an eec-tuner - Brian
94 Lightning
Kenne-Bell Supercharged
78 Trans Am
400 w/nitrous
gasguzzler is offline
post #4 of 4 Old 02-13-2003, 06:21 PM Thread Starter
Thanks for the info. I will try unplugging the computer tonight!
