2500 stall with f303 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 10-03-2015, 01:09 PM Thread Starter
Does anyone know if a 2500 stall would work well with the f303 in the 94 lighting. It's mass air converted .
bill88stang is offline
post #2 of 4 Old 10-03-2015, 01:15 PM
Just Chuck's Avatar
I'd want more stall before I put that cam in a heavy truck.
1989 LX 5.0 - 333 Mexican block, Eagle 4340 neutral3.25" crank, Probe SRS 9cc dome .040 psitons AFR 185 Comp heads, FTI HR cam 239/244 613/613, Edelbrock Victor 5.0, 90mm TB, BBK 1 3/4, C4 and 4500 Circle D converter, 4.10 gears
2012 GT/CS 5.0 - Yellow Blaze Tri-Coat metalic, A6, HID.
Just Chuck is offline
post #3 of 4 Old 10-04-2015, 01:53 AM
I don't know the answer to OPs question.
What I do know is that a 1st gen Ford Lightning weighs roughly 4100 lbs. A modern Mustang weighs about 3800 lbs with the heaviest Mustang curb weight being over 4000 lbs. So think about stall speed like you would a modern car...it ain't a 3100 lb Fox Body.
I had a 1800 rpm stall in my 4600 lb truck with a 306, Edelbrock Performer intake, Powermax 2020 cam, and AFR 165s...1800 wasn't enough and the truck was sluggish off the line since the power band was shifted upward. The truck really came to life once I hit 3500+ up to 6000 RPM though.
Pretty sure I've read that stall speed should be about 500rpm under your peak torque.
With my combination, I would have said a 2800 rpm stall would have been ideal. Maybe even a 3k.
bsfguy is offline
post #4 of 4 Old 12-17-2015, 02:14 AM
I think the major thing about that rate like you would have in today's car...it ain't a 3100 lb Fox Body system.
Melansonc
melansonc98 is offline
2500 stall converter enough with f303 bill88stang 5.0/5.8 Engine Tech 4 10-05-2015 11:03 PM
C4 2500 stall 408-93Coupe Drivetrain Parts 6 12-07-2014 12:11 PM
For Sale new in box ford AOD 2500 stall converter scalper Drivetrain Parts 3 03-16-2014 03:27 PM
For Sale 2500 stall converter for 4r70w MikeJ0522 Drivetrain Parts 0 09-14-2012 09:49 PM
For Sale rebuilt c4 & 2500 stall 65wildstang Drivetrain Parts 0 06-27-2011 06:48 PM
