info about lightning 351 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 11-26-2002, 05:55 PM Thread Starter
I have a 65 stang I have a 302 roller block for it out of an 87 if I were to change my plans to go bigger like 351 would a lightning block be a good canidate? I can get one cheap..just wanted a little info about it before handing over the green....What were the cam specs are pistons notched for bigger cam or what is the limit of cam I can put in it I already have a set of trick flow track heats...any info will help.Thanks
DANNY65 is offline
post #2 of 2 Old 11-26-2002, 06:30 PM
The pistons are dished. I ran a F303 cam with a 1.7 rocker. I would have to say that .550 lift is about the max.I think stock cam is around a .444 lift.
White 94 Lightning
[email protected]
1FASTFORD is offline
