94 L.SHORTBLOCK - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 10-03-2002, 04:26 PM Thread Starter
94 L.SHORTBLOCK
HOW STRONG AND DURIBLE IS THE LIGHTING [94]SHORTBLOCK? THE REASON I ASK IS THAT I WANT TO BUILD A 408 OUT OF IT TO PUT IN MY 90LX ITS GONNA BE CARBED,ANOTHER QUESTION IS WILL A T5 BOLT UP TO A 94 351?WILL THE FLYWHEEL FROM A 302 H.O FIT ON IT?AND WILL THE CLUTCH AND ALL RELATED COMPONETS FIT? I JUST WANT TO KNOW WHAT IM GETTING INTO BEFORE I GO HEAD FIRST INTO IT.IF ANY BODY OUT THERE HAS ALREADY DONE THIS TELL ME YOUR THOUGHTS AND WHAT YOU HAD TO DO TO MAKE IT FIT.THANX
niks4082fst4u is offline
post #2 of 8 Old 10-06-2002, 03:16 PM
i'd also like to know.
89 Black Coupe
93 long block, S-Trim, Cobra Intake, bolt-ons
Champ10187 is offline
post #3 of 8 Old 10-30-2002, 09:58 PM
As far as the tranny bolting up, it should-as long as you use the correct bellhousing for that tranny. You will need a 28 oz. flywheel for the tranny, just use the same clutch setup.
311green94 is offline
post #4 of 8 Old 11-04-2002, 10:54 PM
Smile
the block are very strong the ones i build i used a main support kit with studs,the flywheel should bolt to the 5.8 crank the engine balance need to be with that flywheel because the 5.8 flywheel weight is different.
DANTES INFERNAL is offline
post #5 of 8 Old 11-17-2002, 02:24 PM
Question
WHO HAS ON FOR SELL IN VA OR NC?????
[email protected]
DUI OF HP is offline
post #6 of 8 Old 11-24-2002, 12:25 PM
Talking I have one for sale
I have one M-6010-A351 brand new already machined out to 4.020 bore. This is the same block used in the S351 SALEEN and I thought the F-150 Lightning Truck too but not sure on that one. It is rated good to 750HP and up to 427 cu in, also read in a Ford engine book that it has a NASCAR type iron which promotes better ring seal than a standard block casting.. Reply back to my AOL e mail or PM me.
[email protected]
NXNitrousMustang is offline
post #7 of 8 Old 12-05-2002, 12:24 AM
Contact Alternative Auto in Michigan or check their web site. They have lots of 351 experience!!!! Lidio little shop of blowers!!!!
351mclaren is offline
post #8 of 8 Old 12-05-2002, 04:16 PM
Re: I have one for sale
Originally posted by NXNitrousMustang
I have one M-6010-A351 block. This is the same block used in the S351 SALEEN and I thought the F-150 Lightning Truck too but not sure on that one. It is rated good to 750HP and up to 427 cu in, also read in a Ford engine book that it has a NASCAR type iron which promotes better ring seal than a standard block casting.
[email protected]
This block is NOT the sameone used in the 93-95 Lightning. It is a sportsman block and is better then the stock Lightning block. It has thicker webbing in the mains and is a stronger block. I run mid 11's in my 4200 lb. Lightning if you want to do the math. I have seen some Lightning's run in the 10's with a stock block and mustang's run 9's with a stock Lightning block.(Lidio's yellow mustang)
White 94 Lightning
[email protected]
1FASTFORD is offline
