94 Lightning & 95 F150 5.8l - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 05-20-2014, 12:30 PM Thread Starter
SVTOA Chapter Director
95SVT5.0's Avatar
I did some google searching around, not any real answers that I am looking for. To make things short and sweet, just picked up a 94 Lightning. It has some abuse to it, poor truck. I think the crank may be bent. I changed out the harmonic balancer but still wobbles a lot, may have been doing this for too long prior and damaged the crank. I have a low mileage donor 95 f150 351w with a stock roller setup on the stock short block. I need to get this truck back up and running ASAP, need it for some hauling. Does anyone here see any issue with moving the heads and Intake over to this short block from the lightning? Also going to keep the rods, rockers, and lifters from the donor. Thanks for the help.
South Eastern NC SVTOA Chapter Director
1996 SVT ROUSH Cobra
1994 F150 Lightning
SOLD! 1995 SVT COBRA #1723
95SVT5.0 is offline
post #2 of 5 Old 05-20-2014, 01:54 PM
HIVOLTJ's Avatar
Nope. No problem. The roller cam is probably better than the flat tappet the Lightning came with anyway. If you're feeling froggy swap a 5.0 Mustang HO cam in there (advanced 4*) with some 1.7 roller rockers. Other than the cam the shortblock is all the same. You'll need to use the pushrods from the roller motor, the Lightning ones will be too long.
'90 LX hatch 5.0/5spd = SOLD
'89 LX COUPE 5.0/5spd = SOLD
'94 Lightning #2978 = SOLD
'77 F-150 RCLB 2wd 408 cleveland in the works
HIVOLTJ is offline
post #3 of 5 Old 05-20-2014, 02:01 PM Thread Starter
95SVT5.0's Avatar
Thanks for the quick reply, interested to see wtf happened to this lightning crank. Have you ever heard of this before? I have seen forums where it is possible for the balanced to throw the crank off. It only leaks fluid while driving, from the timing cover seal. But you can see that there is way to much wobble still.
1994 F150 Lightning
95SVT5.0 is offline
post #4 of 5 Old 07-22-2014, 12:27 PM
lightning motor and trans
I am selling a 93 lightning motor and trans for 1500 with 77000 miles. TXT 313-218-3233 or email [email protected]
ibepaid is offline
post #5 of 5 Old 07-24-2014, 08:46 PM
If you do use the regular f150 roller shortblock...use the distributor that was in that block, as the roller and flat tappet camshafts use different distributor cam gears. So dont mix your distributors up during the swap. Lol
357f-150 is offline
For Sale 2002 Ford F150 Lightning dr doom Other Fords and Trades 21 11-02-2013 01:45 PM
F150 lightning seat belts Milkmonster83 Lightning/Harley Davidson F-150 3 08-09-2013 07:08 AM
For Sale feeler: 2002 ford f150 lightning sell/possible trade and cash autoworx Other Fords and Trades 1 09-11-2012 04:20 PM
For Sale 1999 Ford F150 Lightning BallisticCoupe5L Other Fords and Trades 0 03-09-2012 10:45 PM
should i buy lightning motor or standerd f150 motor? stangbanger88 93-95 Lightning 8 01-31-2011 10:25 AM
