Best supercharger? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 09-20-2002, 12:00 PM Thread Starter
zrg91gt's Avatar
Question Best supercharger?
Well, I figured if I sell my other truck I could afford a 2500-3200 supercharger kit. I can get the fms 6psi powerdyne from summit for 2029.00, the powerdyne 6 psi for 2995.00, the kenne bell 1500 6 psi kit for 3199, or the vortech s-trim for 3095.00. Which kit is the most complete, best performing, most reliable, etc. Any advice from experience would be appreciated.
zrg91gt is offline
post #2 of 10 Old 09-20-2002, 02:34 PM
It's all according to how you intend on using your truck ?!
Towing & Big-Block-Like torque,......... Kenne Bell 2200
1/4 mile racing & most power,.............Vortech
Street, with ocasional strip pass,..........Power-Dyne
I've had a Dyne,......and now have a Vortech. Best move I ever made! I went from a 12.97 @ 104 with the Dyne,.........to a 12.41 @ 108 with the Vortech. No other changes !!
Addicted to Speed
93whitelightning is offline
post #3 of 10 Old 10-01-2002, 01:31 PM
Hey 93whitelightning,did you convert to mass air.If not how did you get the speed density computer from screwing up at wot.I've heard of using a check valve to the map sensor but I;m not sure how to do that.Any help would be appreciated..
sydhawk is offline
post #4 of 10 Old 10-01-2002, 02:10 PM
Mike Gager's Avatar
vortech, hands down
Mike Gager is offline
post #5 of 10 Old 10-02-2002, 06:44 PM
MCLFLN's Avatar
Location: Taylorville, Illinois, United States of America
Originally posted by Mike Gager
vortech, hands down
Actually, the Novi 2000 is a better blower than the Vortech S and T trim. I believe there was even an article that showed it out performing the YS-Trim. They are both excellent blowers though.
Quality is top notch on both.
MCLFLN is offline
post #6 of 10 Old 10-02-2002, 07:32 PM
I'm from Michigan and I have the kenne-bell 1500 on my truck running around 7lbs. It is great for towing and playing around town. At the track I believe they will put a stock Lightning around a 14.4. Like what 93WHITELIGHTNING said, just depends on how you use it. PM me if your interested in checking it out some time. I'm up in Midland right now. - Brian
94 Lightning
Kenne-Bell Supercharged
78 Trans Am
400 w/nitrous
gasguzzler is offline
post #7 of 10 Old 10-19-2002, 11:24 PM
I am still runnig S/D and I have no problems i am running a EEC tuner with 42lb inj and a vortech t-trim with 20psi of boost It all depends on the cam that is the main thing when staying s/d you have to keep it around stock lobe sep 114.
95 Red lightning
Vortech T-trim, spearco I/C
Tweecer
357ci, Gt-40 heads, cam motion cam
11.32 @ 119...559hp & 591tq
Justin 95L is offline
post #8 of 10 Old 10-20-2002, 01:26 AM
Hey Justin..Do you run a check valve to prevent the MAP sensor from getting boost.Although I'm doing this in a Mustang,I'm figuring the same rules apply.I'm using a Crane Interceptor ll,and the car runs great until WOT or boost comes on.I think boost is getting to the Map sensor and it puts the EEC into a brain cramp.I'm currently running one check valve but maybe I need to run two.Just wondering what you did to correct that problem..or is it a non issue in Lightnings?...Thanks...
sydhawk is offline
post #9 of 10 Old 10-20-2002, 06:33 PM
Mike Gager's Avatar
yeah ill agree with that but no one makes a novi2000 kit for lightnings so that choice is not an option (unless you can fab your own brackets and such)
post #10 of 10 Old 10-30-2002, 12:41 PM
im running stock heads and cam with a ys trim at 15 #s boost. ive run a best of 11.74 @ 113 with this setup thru a intercooler. im partial to the ys out of all of them...vortechs reliability cant be beat....hands down.
LIGHTNING2FAST is offline
