Finaly figured my problem out...need roller cam advice... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 09-17-2002, 05:55 PM Thread Starter
rl
rl's Avatar
A lifter is wiped out, Its ~1/8" shorter then the rest, and the face is concaved. It was the #2 exhaust lifter, which would explain the backfiring through the intake.
I figure I might as well put a roller cam in it, what cam should I get?
can I use stock mustang lifters, and spider?
I need to get the TFS valve spring kit for gt-40/e7 heads, a new timing chain, a cam, lifters, and a spider..anything else?
Single Turbo EEC-V Powered 1994 Lightning
[email protected]
570rwhp/700rwtq
rl is offline
post #2 of 4 Old 09-18-2002, 02:43 AM
You can use everything from a Mustang, lifters, spider, bars, dist gear the works. Then call Cam Motion up and talk to Terry to get a good cam. You can even have a Mustang roller reground to save a few $$$$
gt40 is offline
post #3 of 4 Old 09-18-2002, 11:44 AM Thread Starter
rl
rl's Avatar
Could I get away with replacing just the lifters?
What lifters would I use for stock replacements..?
[email protected]
570rwhp/700rwtq
rl is offline
post #4 of 4 Old 09-18-2002, 11:58 AM
Mike Gager's Avatar
my guess is if the lifters look like that the cams probably shot also
Mike Gager is offline
