Missing Problem HELP!!!!!!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 08-29-2002, 11:05 AM Thread Starter
Exclamation Missing Problem HELP!!!!!!!
I have a problem that I cannot solve. I have taken the truck to FORD and they cannot solve it either. The truck under normal driving misses and surges very bad. I have done the following: Plugs, plug wire, dist cap & rotor, complete induction clean (FORD Service), checked timing, FORD diagnostics. None of the previous attempts have fixed the problem. Could this be a throttle position sensor as it does seem to happen around the same RPM range?? Could an alternator cause this?? I have disconnected the EGR valve and the problem did not go away. HELP!!!!!!!!!!!
94RedLightning is offline
post #2 of 4 Old 08-29-2002, 08:50 PM
My truck does the same thing. You mainly feel it at cruising speeds. Sometimes when I take off from a stop it is very, very underpowered, and then feels like I took the emergency brake off. I have done all of the same things that you have, but with no luck. I too have had my scan tool on it, and can not find anything.
Anybody?
forcefed88 is offline
post #3 of 4 Old 08-29-2002, 09:37 PM
Have you replaced the fuel filter yet? Mine was doing something similar and I ended up having to get a new battery. Now the surging is gone. It would only do it from a stop or low RPM acceleration. Probably mostly from my pulleys.
89 notch is offline
post #4 of 4 Old 08-30-2002, 10:08 AM Thread Starter
Fuel Filter
Yes i have replaced the fuel filter.
