Cam question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 08-16-2002, 03:58 PM Thread Starter
nunly94gt's Avatar
Lightbulb Cam question
i have a cam out of a 94 lightning block. My friend bought this block and put in a new cam. Well the one that he gave me is a roller cam. Not the flat tappet. What do I have in my possesion? It has the number 12 on the bottom and thats it. Also if someone knows the answer for the specs of the cam I would love it. I know its bigger than the stock HO 5.0l cam. I dunno what it is though. Any help?
1988 Mustang GT. Got my TFS heads and TFS stage 1 cam installed, now onto everything else.
nunly94gt is offline
post #2 of 6 Old 08-16-2002, 04:55 PM
Duration @ 0.050: Int/Exh: 200/214
Degrees advertised duration: Int/Exh: 260/274
Gross Lift: Int/Exh: .260"/.278"
Net Lift with 1.6 rockers: Int/Exh: .416"/.445"
Brian Baskin is offline
post #3 of 6 Old 08-16-2002, 05:17 PM
If the cam is out of the 94 Lightning, and is indeed a roller, then someone did a cam swap.
Beginning in mid-production of the 93 year model, Ford went to a roller block, however, the Lightning remained a hydraulic flat-tappet cam, not a roller.
TraumaPirate is offline
post #4 of 6 Old 08-16-2002, 05:47 PM Thread Starter
nunly94gt's Avatar
Yeah I knew about the flat tappet thing with them. But would that make it a roller conversion cam or a roller cam?
post #5 of 6 Old 08-16-2002, 07:40 PM
Hard to say without looking at the related hardware. If it used regular roller lifters like the mustangs, then it would be a regular roller. But, if it used longer roller lifters, it is a conversion. The conversion used a small base circle cam because most blocks are not roller and do not have the extra support near the top of the lifters.
post #6 of 6 Old 08-16-2002, 08:56 PM Thread Starter
nunly94gt's Avatar
Ill take some pics of the cam and put up here. Then give me yalss thought s agian. Thanx for the info guys!!!
