Hard Shifting - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 17 Old 08-16-2002, 01:45 PM Thread Starter
Hard Shifting
93 Lightning. Anyone had problems with thier Lightning shifting really hard at part throttle? If I disconnect the battery for a while then it shifts normal for about 25 miles, but then its back to neck breaking shifts. I already changed the V.S.S. sensor and nothing. The truck seems to run worse when it's shifting hard. Any ideas?93 Lightning
1995 Crystal White Cobra
331 Stroker
1993 Lightning
351 Windsor
Diabolic is offline
post #2 of 17 Old 08-16-2002, 01:58 PM
rl
rl's Avatar
Mine started doing the same thing last night...but my truck runs like ass all the time. I reset the batter and they fixed it for now...I am goina flush the tranny and see if that helps. I guess there is a solenoid that causes the problem, it sticks or something, easy fix i guess. Do a search on NLOC...
Single Turbo EEC-V Powered 1994 Lightning
[email protected]
570rwhp/700rwtq
rl is offline
post #3 of 17 Old 08-16-2002, 03:18 PM Thread Starter
Just got off the phone with my local Ford dealership, and they told me that it was either the VSS sensor in the rear or a T/R sensor located on the side of the transmission. They told me it was going into limp mode and boosting the line pressure. They didn't know exactly how that would effect the engine performance. Maybe that's why it ran so bad last time at the track! Let me know if and how you fix yours.
331 Stroker
1993 Lightning
351 Windsor
Diabolic is offline
post #4 of 17 Old 08-16-2002, 07:12 PM
rl
rl's Avatar
Mine is doing the same thing...shifting hard and running like CRAP at the track. Did they give you prices for the T/R (if the speedo works, it would only make sense that the VSS is working)
The only thing I wonder, is if it would throw codes, because my truck doesnt throw codes.
[email protected]
570rwhp/700rwtq
rl is offline
post #5 of 17 Old 08-19-2002, 06:28 PM Thread Starter
Installed the T/R sensor yesterday morning and the hard shifting has not returned, YET! The sensor was about $65 from the dealership and took about 15 min to install. I could only get a code with the engine running, but not with the key on, engine off test.
331 Stroker
1993 Lightning
351 Windsor
Diabolic is offline
post #6 of 17 Old 08-19-2002, 08:44 PM
rl
rl's Avatar
could you give me the P/N for it?
Does the truck seem any faster?
[email protected]
570rwhp/700rwtq
rl is offline
post #7 of 17 Old 08-19-2002, 10:39 PM Thread Starter
I can find the part # for ya, but hell yea the truck seems way faster. It might be all in my head though. I'm planning on going back to the track on friday to find out. I'll let ya know along with the part #. It's been 45 miles and still not one hard shift. I need a level 10 2800rpm stall now.
331 Stroker
1993 Lightning
351 Windsor
Diabolic is offline
post #8 of 17 Old 08-20-2002, 11:17 AM
rl
rl's Avatar
that would be great, I wanna get mine fixed ASAP...
let me know on the track times and PN
[email protected]
570rwhp/700rwtq
rl is offline
post #9 of 17 Old 08-20-2002, 01:14 PM
Mike Gager's Avatar
yeah post the part number, my truck has an occassional hard shifting problem also
Mike Gager is offline
post #10 of 17 Old 08-20-2002, 01:45 PM
rl
rl's Avatar
Humz, I just hope it makes mine stop shifting so high and running like crap
[email protected]
570rwhp/700rwtq
rl is offline
post #11 of 17 Old 08-21-2002, 10:17 AM
91Steeda's Avatar
Worth a shot.
Mine shifts hard when I'm on the gas but other than that it shifts pretty easy.
My brother's 93 is starting to hard shift at half throttle too, might have to give it a try on his.
91Steeda is offline
post #12 of 17 Old 08-21-2002, 10:43 AM
rl
rl's Avatar
I ran a KOER test, and it threw all kinds of codes, none for the tranny...
I got a ACT ECT and TPS code..
[email protected]
570rwhp/700rwtq
rl is offline
post #13 of 17 Old 08-21-2002, 12:41 PM Thread Starter
You might be getting the TPS voltage too high code if you have upped the voltage to .98 or so. The ECT code may be caused if you tested the motor when it was not at operating temp. I am taking the truck to the track tonight to see how it does. So far after replacing the VSS and the T/R sensor no problems with hard shifts(115 miles).
331 Stroker
1993 Lightning
351 Windsor
Diabolic is offline
post #14 of 17 Old 09-10-2002, 03:02 PM
SLOW5.0's Avatar
Diabolic,
stupid question...wtf is a t/r sensor?
If I replace this sensor and it makes my trans shift smooth all the time, I will drive to your house and bring you a mc'd's extra value meal of your choice!!!
Mine only seems to do it when im towing and then it keeps doing it for like a week after. Well, over the summer i go to the track every weekend so it usually starts shifting smooth for like one day before I tow again. And seems to get real bad gas milage and has no throttle response when its shifting hard.
Thanks!
91 Black Notch, 99 WS6 TA, 00 GT, 08 Gsxr1000, 06 R1, 06 R6, 07 Gsxr600
SLOW5.0 is offline
post #15 of 17 Old 09-12-2002, 03:49 PM Thread Starter
I'm not really sure what it stands for but I was told that it tells the transmission when and what gear to shift to. It also controlls the line pressure for the shift firmness(so I was told). I replaced mine, but to no avail cuz it started doing it again. I know it will sound strange and I have no explination for it, but it always started shifting hard when i would come to a particular 4-way in front of an electric power station. I tested this by disconnecting the computer and getting it to shift normal and sten pulling up to the 4-way. Sure enough as soon as I pulled away came the hard 1-2 followed by the 3 shift. I have since been avoiding the intersection and have put over 300 miles without a problem.
331 Stroker
1993 Lightning
351 Windsor
Diabolic is offline
post #16 of 17 Old 09-12-2002, 08:34 PM
Lightbulb
electro-magnetic interference
ijuslikefords is offline
post #17 of 17 Old 09-12-2002, 10:23 PM
Mike Gager's Avatar
your nick name wouldnt happen to be "spooky" would it?
The truth is out there!
