New track times! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 15 Old 08-14-2002, 09:48 PM Thread Starter
rl
rl's Avatar
New track times!
DIE TRUCK DIE!!!
cleaned the K&N, checked codes, new plugs/wires/cap/rotor, moved the timing from 7* to 14*...
[email protected] ph33r.
I have the slowest lightning ever produced.
It falls flat on its face above 3700 or so.
Single Turbo EEC-V Powered 1994 Lightning
[email protected]
570rwhp/700rwtq
rl is offline
post #2 of 15 Old 08-14-2002, 10:07 PM
Do you have a breakdown of the run? How many miles are on it? Something's definitely wrong there.
Brian Baskin is offline
post #3 of 15 Old 08-14-2002, 10:22 PM Thread Starter
rl
rl's Avatar
92k miles
60' 2.308
330' 6.682
1/8 10.366 @ 66.14mph
1000 13.579
1/4 16.302 @82.13
[email protected]
570rwhp/700rwtq
rl is offline
post #4 of 15 Old 08-14-2002, 11:59 PM
How old is your fuel filter?
94 Lightning
Kenne-Bell Supercharged
78 Trans Am
400 w/nitrous
gasguzzler is offline
post #5 of 15 Old 08-15-2002, 12:35 AM
Mike Gager's Avatar
hmmm i suppose its possible your valve springs might be worn out
check the fuel filter if you havent already, other then that i dont know
Looking for Fox body Fairmont, Zephyr, Cougar, LTD, Marquis or Granada wagon
Mike Gager is offline
post #6 of 15 Old 08-15-2002, 04:26 AM Thread Starter
rl
rl's Avatar
I would imagine they are stock..dunno though, they are on the list.
would a vac. leak cause this? it pulls 18-19" @ idle (~900rpm in park)
[email protected]
570rwhp/700rwtq
rl is offline
post #7 of 15 Old 08-15-2002, 10:19 AM
91Steeda's Avatar
I don't think a vacuum leak would cause that kind of slow down.
Dunno if this has been said yet, but is the spout connector clip together? I know it seems kinda of stupid but trying to throw out some ideas.
Take to the Ford garage and have them wipe the injectors clean. That might help. Maybe. lol
91Steeda is offline
post #8 of 15 Old 08-15-2002, 10:27 AM Thread Starter
rl
rl's Avatar
LOL! Let ford fix it....haha
The spout connector is in.
[email protected]
570rwhp/700rwtq
rl is offline
post #9 of 15 Old 08-16-2002, 05:33 PM
The pointer could be bent for the timing, the balancer may have spun on itself giving you a bad timing reading. You are pulling the spout when you check the timing, right?
Check your timing with another timing gun.
What elevation are you running at? Are you spinning when you launch, 2.3 is off the norm, unless you're spinning.
You may have too much oil on your K&N. Try running with just an open throttle body and see if that helps... more air, hot or otherwise is better than less air.
TraumaPirate is offline
post #10 of 15 Old 09-02-2002, 05:30 PM
NaturalAspired's Avatar
sounds like you are running WAY lean..borrow someone's mass air meter and see if that solves it (my stang was doing the same thing, mass air meter fixed it) check vacume leaks
up the fuel pressure to say 50psi, if it runs better (but still will run like ass) then you are running lean..go from there..what about your roller rockers.? were they installed correctly? yes a nasty vacume leak can make it run like this also..
-Dave-
93 Calypso notch... Built 306 H/C/I etc... Runs 11.9's
NaturalAspired is offline
post #11 of 15 Old 09-02-2002, 06:24 PM Thread Starter
rl
rl's Avatar
had it on a dyno, its backfiring up top, made 198rwhp 290rwtq.
AF was good, but all over the place between 12:1-13:1, probably from the backfring, when it would break up, it was smoking a little bit...seems ignition related, I have checked the timing with 3 different lights, it runs MUCH worse at 12 than 14...backfiring wise...
[email protected]
570rwhp/700rwtq
rl is offline
post #12 of 15 Old 09-02-2002, 07:22 PM
Our trucks have weak valve springs and should be replaced. Mine were so worn out at 70,000 I couldn't rev it past 4600. you also need to look at the timing chain
Jerry
94 Lightning
Intercooled Novi 2000
[email protected]
blownlightning is offline
post #13 of 15 Old 09-03-2002, 03:47 AM Thread Starter
rl
rl's Avatar
Jerry
what valve springs make for a good replacment?
[email protected]
570rwhp/700rwtq
rl is offline
post #14 of 15 Old 09-03-2002, 10:12 AM
Mike Gager's Avatar
crane makes a gt40 head valve spring package i believe. ford also has one to or use to
post #15 of 15 Old 09-03-2002, 11:15 AM Thread Starter
rl
rl's Avatar
Can I use the same springs I would use on hydro roller heads?
if so I'll get the TFS kit
[email protected]
570rwhp/700rwtq
rl is offline
