OK...whats wrong with my lightning? (ran HORRIBLE) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 08-08-2002, 05:25 AM Thread Starter
rl
rl's Avatar
[email protected] acceptable!
it doesnt throw check engine lights, though I do need to scan it for codes. It has (as far as i know) a exhaust without cats from just behind the stock crossover back (sounds like crap...redneck style flowmasters) A K&N and possibly a chip.
I bought it yesterday, changed the oil, put new plugs/cap/rotor/wires on, didnt help one bit.
It idles at 800-900rpm, driveablility is great, it seems to shift HIGH, 1-2 is 5200 2-3 is 5300 or so, after 4500rpm or so it just FALLS on its face. It feels like its shifting like its at WOT, but the truck isnt at WOT....doesnt make any power.
The ONLY thing I can think of is the plenum spacer is messed up...or this thing doesnt have gt40 irons on it.
Any other ideas? At part throttle, from 2500-4500 it seems to pull strong, just at WOT it falls on its face...
Single Turbo EEC-V Powered 1994 Lightning
[email protected]
570rwhp/700rwtq
rl is offline
post #2 of 6 Old 08-08-2002, 09:44 AM
Mike Gager's Avatar
yeah that does suck
id say see if it does have a chip and pull it out and see if the shifts change at all
make sure OD is off when you run
check your ignition timing, make sure your plug wires are on the right plugs, etc
oh yeah do you know how to check if you have GT40 heads? ( i have heard of this problem more then once!)
Mike Gager is offline
post #3 of 6 Old 08-08-2002, 10:18 AM Thread Starter
rl
rl's Avatar
Originally posted by Mike Gager
yeah that does suck
why do i run with OD off, will that change how it shifts?
They are gt40 irons, The headers have never been off..
[email protected]
570rwhp/700rwtq
rl is offline
post #4 of 6 Old 08-08-2002, 11:16 AM
Mike Gager's Avatar
well under full throttle it shouldnt shift to OD but just to be on the safe side i always turn my OD off before i run
quick way to tell if they are gt40s is to take a look at the front intake side corner of the passenger side, should have a small "GT" marking. im sure they are but i do know of one guy who got stuck with regular heads and also know of another rolling around somewhere with E7 heads on it
post #5 of 6 Old 08-08-2002, 08:49 PM
fordfreak95's Avatar
Check your TPS sensor. Should be .98 volts with the truck off and the throttle closed and around 4.6 volts(can't remember if it's 4.3 or 4.6) at wide open throttle(truck off). Check your timing with the chip unpluged if it does have one. Timing on a L with 93 oct gas should be around 14*-16*. Check fuel PSI, O2 sensor,etc.....
Good luck! Matt
Mineral Gray 05 GT 5spd..JLT CAi, SCT 2 w/Bren 93 oct tune, ASP Under drives, Ford OEM 4.10 gears, Pro-50 S.S., Saleen 18" wheels w/F1 Supercar 255/285, Pypes bomb axle back, Pypes splice in X pipe, Roush rear 1" lowering springs and a Spohn adjustable panhard bar.
fordfreak95 is offline
post #6 of 6 Old 08-08-2002, 09:02 PM
What do your plugs look like after a run? I agree with the rest... check your fuel pressure, tps, timing, etc.
It wouldn't hurt to change your fuel filter, I picked up 2 psi when I changed mine.
Just in case you don't know how to check the timing on a Lightning, click on the following link.
Checking The Timing
TraumaPirate is offline
