351w stock hp - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 08-05-2002, 09:13 AM Thread Starter
millhouse's Avatar
351w stock hp
I may be buying a 95 lightning engine complete, and was wonder if anyone know the advertised and actual horsepower for the 351w.
2016 Ruby Red Mustang GT PP
Prior Cars
millhouse is offline
post #2 of 5 Old 08-05-2002, 10:39 AM
Don 95Vert's Avatar
Re: 351w stock hp
240
95 Lightning - Slow
95 Convertible 357 turbo
10.5/135 @ 3800#
SCT Tuned
Don 95Vert is offline
post #3 of 5 Old 08-05-2002, 11:07 AM Thread Starter
millhouse's Avatar
Is that actual at the flywheel, or advertised at the flywheel? Also, what kind of improvement would it be if I dropped it in my 89lx notch?
Prior Cars
post #4 of 5 Old 08-05-2002, 11:36 AM
Horsepower (SAE Net) 240 HP @ 4200 RPM
Torque 340 lbs./ft. @ 3200 RPM
Advertised.
They're maybe a tad underrated. Some stock Lightning dynoing around 215-220HP. But it's the torque that the highlight Putting just this engine into a stock notch will probably net you 14.5 times, at the slowest. Our 4500# trucks run low 15s stock. A notch alone is over #1000 lighter. There's a full second
Brian Baskin is offline
post #5 of 5 Old 08-05-2002, 11:57 AM Thread Starter
millhouse's Avatar
Thanks Brian Baskin. I figured what better place to get an accurate responce would be directly from the source. If a stock lightning dyno's 215-220 with an aod, it should dyno a little more with a manual trans, 24lb injectors, and maf right?
Prior Cars
