Cobra roller rockers on Gen I Linghtning - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 08-04-2002, 08:58 PM Thread Starter
Question Cobra roller rockers on Gen I Linghtning
Has anyone installed the "Crane" / FRPP Cobra roller rockers on a Gen I 351 Lightning? Did you have any problem with the install? What was the piston to vavle clearance like? Were they noisey? Would you do it again?
Thanks,
Eric
imNARUSH is offline
post #2 of 2 Old 08-04-2002, 10:20 PM
I have them on my truck, actually, I'm on my second set of Crane rockers. I bolt broke on mine after a year, so I replaced all of the rockers. No problem with the install, just follow the instructions if you have to shim them. The major pain on the install is the upper intake... you have to unbolt it and slide it off to the side to reach the passenger side. They are as quiet as the stockers and unless you have gone with a big cam, valve clearance is not a problem.
As far as performance, I didn't really see any increase, but others have.
Good Luck
TraumaPirate is offline
