Carb'd Lightning Engine - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 10-07-2010, 04:51 PM Thread Starter
I am putting an Lightning Shortblock in my '69 Mach 1 and am trying to figure out what head/ cam / intake combo should get me to my goal of 450hp (atleast)
Driveability is a huge concern though - what do you guys recomend?
'69 Mach 1
www.BuckeyeStangs.com
Junior2561 is offline
post #2 of 6 Old 10-11-2010, 07:37 PM
fastcobra50's Avatar
Trader Feedback: (77)
If drivability is a huge concern your probably not going to make over 450 hp without a power adder. Sure you can make that much power with a 351 n/a but it's not going to pur like a kitten. Its also going to lack low end power.
Craig Shepard
Straightline Performance
fastcobra50 is offline
post #3 of 6 Old 03-21-2011, 11:31 AM
a good combo is a GT40 intake, eddy performers, performer rpm's or victor jr's, or AFR 185 or 205, or TFS and a comp XE268 to XE272(i think or 274). That should put you right at the 400-450 mark, depending on compression.
95 Lightning-Black #772
ASAP is offline
post #4 of 6 Old 03-22-2011, 02:12 PM
When u pop the heads intake and cam out you then just have a basic 351. Nothing different from a regular F150. So u can go back over to the mustang section and get more answers.
95 Mustang 351 MM PHB/TA MM2 rear shocks and coilovers
17x10.5 sqaure
95Blitz is offline
post #5 of 6 Old 03-23-2011, 07:37 PM
Oh, the best carb intake i've used for this set up is a edelbrock performer rpm air gap. Did wonders on a 351 i built when i changed from a edelbrock performer to the rpm air gap.
ASAP is offline
post #6 of 6 Old 03-27-2011, 08:28 PM
Banned Alleged Scammer
Trader Feedback: (146)
Spend the money on the heads. I would do AFR 205's with a custom hydraulic roller camshaft from Ed Curtis @ FTI. Get the heads milled to put your compression to around 10.5-1. Use a ported Edelbrock RPM Air Gap and a 750 cfm double pump carb. You should get close to 450 at the crank and around 375-380 to the wheels depending on the trans.
If you want 450 to the wheels, stroke it out to a 418W and use a ported Vic Jr intake on it. Up size the carb to an 850 cfm, leave the compression ratio at about 10.5-1 and let Ed grind the cam for the larger cubic inches.
Carb / Engine Guru's Help with my Engine...Part 2 sum87mustang 5.0/5.8 Engine Tech 32 05-13-2005 04:48 PM
Is a Lightning engine physically bigger than an 03 Cobra engine? fakesnake.com Lightning/Harley Davidson F-150 4 12-23-2003 07:11 PM
5.4L Lightning Engine in SN95 engine bay?? 96GT_Czech GT & SOHC 15 07-05-2003 11:23 AM
OK carb guys, questions on carb spacers and effect on engine?? phils90sc General Mustang Tech 2 05-05-2003 11:53 PM
Lightning Engine/Harley F150 Engine nairbfs Lightning/Harley Davidson F-150 7 10-01-2002 11:56 PM
