What tire size when running second gen wheels? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 08-30-2010, 09:19 PM Thread Starter
As the title says...what tire size would fit best and not cause any speedometer\shifting\rubbing issues?
wheels are 99 lightning 18x9.5's
truck is 95 lightning with stock ride height
....and yes i already know about the bolt pattern...already solved...just need tires
Wasn't sure if the stock 295-45-18 tires that came on the new body lightnings would work..thoughts?
AWD and boost...I think my Mustang is getting jealous
v8lover is offline
post #2 of 5 Old 08-31-2010, 08:48 AM
Don 95Vert's Avatar
I think I'm running the 295's with no issues except for slight binding on on the fronts on real tight turns. I'll check later on to be 100% sure though. The speedo doesn't matter as the pickup is off the ring gear in Gen 1 Lightnings...
95 Lightning - Slow
95 Convertible 357 turbo
10.5/135 @ 3800#
SCT Tuned
Don 95Vert is offline
post #3 of 5 Old 08-31-2010, 07:31 PM Thread Starter
good to know about the speedo. i've had a 'few' lightnings in my time but have never put a set of wheels on one...figured id try something new.
v8lover is offline
post #4 of 5 Old 09-03-2010, 01:03 PM
HIVOLTJ's Avatar
No, no, no. The speedo is unaffected by gear changes, tire diameter changes need to be accounted for. I believe stock Gen 2 tires are shorter. Search PSOM on www.nloc.net you need to find the constant for the tire diameter and program the PSOM with it.
'90 LX hatch 5.0/5spd = SOLD
'89 LX COUPE 5.0/5spd = SOLD
'94 Lightning #2978 = SOLD
'77 F-150 RCLB 2wd 408 cleveland in the works
HIVOLTJ is offline
post #5 of 5 Old 09-03-2010, 11:20 PM
Don 95Vert's Avatar
Whoops, you are right, dunno what I was thinking when I posted that. But there is no way to correct the speedo in the PCM.... Anyway, my speed with those tires is still spot on - checked with a GPS....
95 Lightning - Slow
10.5/135 @ 3800#
SCT Tuned
Tire size on wheels Santana Wheels and Tires 9 08-29-2005 11:31 PM
who's running sportline springs , fox body, with fms cobra r's, need your tire size. p01rogue Wheels and Tires 3 02-20-2005 10:30 AM
What Tire Size is Better For These Wheels??? milleniumGT Wheels and Tires 3 03-07-2004 02:09 AM
tire size 17x9 on a fox what are you running five0 Wheels and Tires 1 09-17-2003 08:39 PM
Any running 18x9's what size tire are you running ?? amicropimp Wheels and Tires 5 02-20-2003 01:54 AM
