Victor JunioR heads on stock bottom end ? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 08-06-2010, 04:46 PM Thread Starter
saleen9973's Avatar
Any guys running a Victor jr head on the stock bottom end? I was wondering if a 2.02 valve will clear the stock piston as long as i don't go crazy with durration on the cam?
saleen9973 is offline
post #2 of 13 Old 08-07-2010, 12:47 AM
splitblock302's Avatar
My vic's are 2.05 ALWAYS do a P-T-V check I don't know your cam events
87 hatch c-4,pump gas 408w,10.61 at 128 N/A on trans brake at 4k/10.68 at 126 on footbrake flash from 1600/hoosier QTP /as it sits street legal with tags/ FTI cam 3.90 spool sounds like a kitten,thanks Ed-FTI
THAT SH-- AIN'T FAST RACING /RANGERS LEAD THE WAY RagingA$$holeNeverGetsEnoughRest
splitblock302 is offline
post #3 of 13 Old 08-07-2010, 09:09 AM Thread Starter
saleen9973's Avatar
I was thinking about running the comp nx-274hr cam 114 lobe sep/on the intake duration 274 duration @ .50 224 lift .555. Exhaust duration 286 duration @ .50 236 lift .570.
post #4 of 13 Old 08-07-2010, 12:09 PM
Cobra427's Avatar
You should have no issues. That cam is comperable to the Fcam and 1.7's on my father's car which is running AFR 185's.
93 SSP 3220 lbs,W/C T-5,3.90's,ported gt40 irons,stock valves,cut/ported Cobra upper,ported lower.30# inj.SVT MAF,Bcam/1.7'sN/[email protected] 1/[email protected] DA 1083,1.74 60',old Nitto Dr's Catted UPR X, stock airbox and full emissions equip still on the car.passes Cali emissions
Cobra427 is offline
post #5 of 13 Old 08-07-2010, 08:53 PM Thread Starter
saleen9973's Avatar
sounds good. I was thinking that cam is expensive for 30 bucks more i can have a custom one done i may contact a cam guy and talk to him.
post #6 of 13 Old 09-06-2010, 01:49 AM
I have vic's on my stock SB with no Issue's.
Quick86Coupe is offline
post #7 of 13 Old 09-07-2010, 09:41 PM
you'll have no problem
biznotchlx is offline
post #8 of 13 Old 09-12-2010, 04:03 PM
S-Trimmed302's Avatar
Trader Feedback: (124)
Dont listen to ANYONE that point blank says you WONT have any problems..ALWAYS and I mean ALWAYS check your P/V clearance with ANY cam you use or the first time you fire the motor could really REALLY Ruin your day and cost you ALOT of $ for being stupid and not checking..Trust me I have seen it happen..Just bcause one person had plenty of Clearance dont mean YOU will!Check it!
My 92 Coupe- Under construction - Dart 347, TFS 205 11R heads,Custom Cam by Brian Friedentag "freezy74",TFS Box R Intake, 75mm Accufab TB, Hooker Supercomp 1 3/4" Full Lengths,Vortech Pass side YSI,8" Crank,2.85 blower pulley,Treadstone 1245-28 Intercooler,Snow Stage 2 Meth kit
S-Trimmed302 is offline
post #9 of 13 Old 09-19-2010, 09:29 AM
dgrobels's Avatar
i ran them on a stock buttom end and needed to notch the pistons, wasier way then I did is to use a dremel and open up the eye brow so it will clear the 2.05 intake valve
dgrobels is offline
post #10 of 13 Old 09-19-2010, 03:03 PM
Dr.Shift's Avatar
Trader Feedback: (29)
Im not sure what my cam is but the eyebrows on my pistons had to be opened up as well
Dr.Shift is offline
post #11 of 13 Old 09-19-2010, 10:01 PM
dgrobels's Avatar
I nothced mine using the isky eyebrow cutter it took a little more time then using a dremel but it worked I was running the TFS stage3 cam and the valves cleared but it tan like crap and needed a tune or a better MAF
bottom line I wouldnt put a set of $1200+ and take a big ol guess At ruining my valves but not notching them, itll only take you a bout an hour or two tops!
http://www.stangnet.com/mustang-foru...k-pistons.html
http://www.lonestarstangs.com/forum/...ool-57460.html
dgrobels is offline
post #12 of 13 Old 09-23-2010, 09:41 AM
Always check your clearances
zfan is offline
post #13 of 13 Old 12-25-2010, 08:43 PM
Trader Feedback: (30)
My stock pistons had to be notched for my AFR heads. Definately check your clearance. When I bought my heads, I was talking with Ed Curtis and he said Fords quality control was pretty poor. You could have 9 out of 10 motors be fine, but it would be my luck to get the tenth that eats itself when you start it up! Spend the time / money to make it right so you don't pay in the long run!
1993 Black Lightning #2103
1995 White Lightning #585
1995 Black Lightning #184 Black hole where all my money goes!
1995 Mustang GT
madramper is offline
Some Twisted Wedge 11R Head Insight - 86 BONE STOCK Bottom End Rock4451 5.0/5.8 Engine Tech 42 02-01-2016 09:35 AM
stock bottom end compression with 50cc head 427steve 5.0/5.8 Engine Tech 3 09-10-2015 11:48 PM
stock bottom end 351w and 350rwhp? kolb02 5.0/5.8 Engine Tech 19 12-06-2013 09:01 AM
87 mustang lx stock bottom end 12.72 e/t mustangwild 5.0/5.8 Engine Tech 6 11-04-2013 01:25 PM
Official Mod Shootout Radial rules Dave King GT & SOHC 8 12-22-2001 10:37 AM
