What is the difference between the lighning 351 and regular production 351s - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 01-20-2010, 11:18 PM Thread Starter
If I were to find a lightning motor could I just stick a decent 4 bbl intake and carb on it and it be a decent motor for a non EFI application
junkyardjeff is offline
post #2 of 9 Old 01-20-2010, 11:54 PM
Those are roller blocks from 94 and up I believe.Some say 93 also.F4te
I am thinking they were not roller cammed though.
Someone will chime in about it better than I can.
csgoody is offline
post #3 of 9 Old 01-21-2010, 12:27 AM
Yeah it's got GT40 heads but if your going carb pull the small cam and put a big bump stick in it. Yeah the very early 93's have the non roller blocks, the late 93-95 have roller ready blocks. Meaning it's drilled and tapped for the hold down and the lifter bores are right for the dog bones.
95 Mustang 351 MM PHB/TA MM2 rear shocks and coilovers
17x10.5 sqaure
95Blitz is offline
post #4 of 9 Old 01-29-2010, 03:40 PM
TALLEN08's Avatar
bump
TALLEN08 is offline
post #5 of 9 Old 01-31-2010, 12:23 AM
the 93 is not a full roller bloce but it can be made into a roller.if you want one thats already a roller get a F4TE out of a 96 van,bronco
st pete chad is offline
post #6 of 9 Old 01-31-2010, 01:08 PM
This is the correct answer.
17x10.5 sqaure
95Blitz is offline
post #7 of 9 Old 02-16-2010, 12:28 AM
The Lightning engine was a hydraulic flat-tappet camshafted 351. The Ford part number to that cam was an early 70's part number, so the cam is not that hot of a cam. It has cast iron GT40 heads, although the Cobra got the 1.7 roller rockers, the Lightning uses 'sled' style regular 1.6 rockers. The other guys are correct about the F4TE being roller cam ready. Honestly, other than the heads (and intake) they are not that much different from a regular production 351.
2nd owner 1994 Lightning #2563
94RCODE is offline
post #8 of 9 Old 02-21-2010, 12:58 AM
4200lb.Girlfriend's Avatar
I have a '95 Lightning and a regular '95 F-150 with the 351W in it. In addition to the info. posted above:
Both trucks have the F4TE block, but only the regular F-150 has a roller cam installed in it from the factory.
Stock horsepower numbers are 240 for the Lightning, and 210 for the regular F-150.
The Lightning has dish style hypereutectic pistons and an 8.8:1 compression ratio, but I don't know what the regular F-150 has, though I've read that the compression ration is the same, and they always seem to mention the Lightning's hypereutectic pistons in a way that makes it sound like the regular 351W doesn't have them.
4200lb.Girlfriend is offline
post #9 of 9 Old 03-03-2010, 10:30 PM
Stang Seller's Avatar
Trader Feedback: (26)
That's because the regular F series had cast pistons, and the Lightnings had hypereutectic pistons. A stock Lightning motor with a dual plane intake, 750 carb and a hotter camshaft would really wake up..... probably to the tune of 80HP and 40-50lb ft torque.
'86 GT T-Top - 5.0/T5 - in pieces.
'90 LX Vert - stock
'83 Cutlass Cruiser LS/LR4 swapped, TH350, 8.8 rear swap
Stang Seller is offline
need lighning gt/40 351 5.8 lower intake ngc414 Windsor Engine Parts 0 07-19-2006 02:20 PM
what's the difference between HO,and regular 5.0 crankshafts? Ehardy1971 5.0/5.8 Engine Tech 4 01-02-2004 03:32 PM
What is the difference between '03 Bilsteins and regular ones ? SnkBtn99 Road Racing/Auto X 6 01-20-2003 12:00 PM
What's the difference between a Mustang dyno and a regular one? 97MattGT GT & SOHC 3 02-17-2002 08:07 AM
What's the difference between HO and regular 5.0? shmokinjoe 5.0/5.8 Engine Tech 10 12-01-2001 07:08 PM
