roller block applications - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 08-04-2009, 01:44 PM Thread Starter
I've been outta circulation for a while,
& can't even remember what I've forgotten...
Are ALL F4TE blocks cast for roller lifters? Will an F4TE block accept flat tappets (w/the corresponding cam)? Were F4TE blocks installed in any applications BESIDES Lightnings?
All info (especially links to reference sites) appreciated.
Much obliged,
Matt
tomhorn1913 is offline
post #2 of 8 Old 08-04-2009, 06:43 PM
Yes all F4TE blocks are roller ready.
Yes they will accept a flat tappet setup. That is what the Gen 1 has in it from the factory.
Not sure about other applications.
www.nloc.net for Gen 1 Lightning info.
'94 Lightning 383ci w/Vortech S-Trim +too much to fit in the sig.
gn87gt2000 is offline
post #3 of 8 Old 08-05-2009, 02:21 PM Thread Starter
Thank you, sir!
Very helpful info.
Much obliged,
Matt
post #4 of 8 Old 08-05-2009, 09:18 PM
I forgot to mention, the F4TE has the holes drilled for the spider hold down piece that holds the dogbones, but they have to be tapped.
post #5 of 8 Old 08-06-2009, 02:17 AM
the top of the lifter bore bosses were machined to the height for a hydraulic roller lifter starting about 1995..allthough not every engine was equipped with a hydraulic roller cam / lifter....
the block was in vans and other trucks that employed a hydraulic flat lifter and cast iron cam....
Kato Engineering is offline
post #6 of 8 Old 08-08-2009, 12:57 AM
Lets see F150's 93-96, F250's till 97 non HD's, E150-250, same years, Bronco's 93 maybe -96. I think thats it.
95 Mustang 351 MM PHB/TA MM2 rear shocks and coilovers
17x10.5 sqaure
95Blitz is offline
post #7 of 8 Old 08-09-2009, 05:41 PM
All F and E series trucks(except Lightning) from '94 on with a 5.8 had a factory roller cam in the F4TE block, that goes for the Bronco too and any cab & chassis combo.
Paul O
____________________
1990 F150 4x4, 5.0, XE264HR, Longtubes and 3" single, FRPP MAF Conversion, TweecerRT, Innovate LC-1: Building '85 357, Dart Iron Eagles, Crane 444232, Typhoon EFI, 1.7 RR, 24lb injectors.
conanski is offline
post #8 of 8 Old 08-10-2009, 12:37 AM
DUNNO WHY IT MATTERS, because if it has a valve cover that LOOKS like it is a common 351.,
..then IT IS..
........because after the pushrod V-8...
there was NO OTHER variation...
other than a V-10 / modular type...
THE BLOCK WERE ALL THE SAME. from 1993
WTT: My complete 2.3 turbo motor, for a 69-74 351w block or newer roller block 5.0calypso93lx Windsor Engine Parts 3 01-22-2007 10:36 AM
Roller rockers, roller cam, roller lifters, 351w block, crank, rods, pistons, dizzy, zrg91gt Windsor Engine Parts 0 11-20-2006 09:11 AM
WTB: Crane connected lifters to convert non roller block to roller block [email protected] Windsor Engine Parts 7 04-22-2006 12:17 AM
z-stud with roller block (early manual with roller block) N2O88 Classic Mustangs & Fords 2 07-08-2004 08:23 PM
How hard to turn non-roller block to roller block ?? [email protected] General Mustang Tech 2 09-09-2003 08:52 PM
