EEC question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 07-12-2009, 10:50 PM Thread Starter
EEC question
Sorry to post in the Lightning forum, but I'm getting no responces in EEC tech. My 88 Bronco has a 5.0 non-H.O. engine. It's a roller cam motor but has standard firing order. I want to swap in the factory motor from my 90 GT. Can I use the EEC from a speed-density 351W Bronco so I don't have to swap cams?
baldguy is offline
post #2 of 4 Old 07-12-2009, 11:16 PM
You will always have a ruff idle and a miss also
mustang3091 is offline
post #3 of 4 Old 07-13-2009, 02:11 AM
Yes and no the computer thinks it's running a 351 unless you have a tuner and it's only running a 302. So the computer will not see the correct load. I would just swap the cams out.
95 Mustang 351 MM PHB/TA MM2 rear shocks and coilovers
17x10.5 sqaure
95Blitz is offline
post #4 of 4 Old 07-15-2009, 09:01 AM
You don't need to change the computer to use the HO, just drop the motor in there plug it in and wire the plugs 13726548. The truck SD system is batch fired and doesn't care about the firing order, both the 5.0 and 5.8 SD trucks have the injectors wired exactly the same from the factory.
Paul O
____________________
1990 F150 4x4, 5.0, XE264HR, Longtubes and 3" single, FRPP MAF Conversion, TweecerRT, Innovate LC-1: Building '85 357, Dart Iron Eagles, Crane 444232, Typhoon EFI, 1.7 RR, 24lb injectors.
conanski is offline
eec-iv question feldz82 EEC Tech 2 12-09-2005 11:01 AM
EEC question please help AJAYSTANG EEC Tech 8 08-01-2005 11:04 AM
EEC-IV & EEC-V question Mikes94GT EEC Tech 5 01-31-2005 10:13 AM
EEC-IV question Dirt EEC Tech 2 12-26-2004 11:12 AM
EEC Question BigC3416 94/95 Tech 3 10-31-2003 09:06 AM
