Gen 1 Lightning-Towing - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 17 Old 05-03-2009, 04:14 PM Thread Starter
Thunder5.0's Avatar
Question Gen 1 Lightning-Towing
Are the Gen 1's good for towing? Do you think pulling a fox body with it is too much weight?
Thunder5.0 is offline
post #2 of 17 Old 05-03-2009, 09:50 PM
NC STANG GUY's Avatar
Trader Feedback: (176)
Had two gen 1 L's over the years 93 and a 94. Pulled my foxbody coupe with both of them. Did fine.
NC STANG GUY is offline
post #3 of 17 Old 05-05-2009, 12:14 PM
LAPS 5.0LX's Avatar
The Gen 1's are very capable of pulling more then the 5000# there rated for. I put on a 12000# F250 hitch, air bags and electric brake controller on mine and pulled a 11000# 31ft offshore boat around. It did well, but was limited by its short wheel base. In hindsight, while I made it as safe as possible, I wouldnt recommend doing what I did, but a 5k to 8k setup, the L will do fine.
When towing just take extra precautions. Airbags help greatly on the lower L, load bars, electric brakes, proper tire pressures, electric brake controller. The same suspension that gives it the good handling, also makes it a good tow rig.
BTW, I now have a 35ft offshore boat that I pull with my brothers F250 diesel, much safer for that kind of load(13000#).
LAP
Proud owner of a family of fine Fords:
1989 5.8 Vortech Coupe, 2005 6.0 Eddie Bauer Excursion, 2006 Explorer Limited V8
LAPS 5.0LX is offline
post #4 of 17 Old 05-05-2009, 01:23 PM Thread Starter
Thunder5.0's Avatar
Nice. I was going to use a tow dolly instead of a trailer to keep it safe.
post #5 of 17 Old 05-06-2009, 05:51 AM
LAPS 5.0LX's Avatar
I've towed boats, rv's,car trailers, and a landscape trailer filled with 4 wheelers, but never on a tow dolly. The truck can handle a tandom car trailer, I think I would rather have my Mustang on a trailer then latched to a dolly IMO.
Keep in mind that a tow dolly either has no brakes or a surge brake. Most boat trailers use surge brakes, but electric brakes(found on a car trailer) are superior in controlling a swaying trailer, since you can apply the trailer brakes without using the truck brakes, which will stop a swaying trailer in a flash. Surge brakes work good when you have a bigger/heavier truck.
LAP
post #6 of 17 Old 05-07-2009, 06:37 AM
Ive had 3 gen 1s and a gen 2.
Towed with all of them.
Overload springs, brake controller and youll be fine.
the gen 1s are lacking in the power dept stock, but they tow fine nonetheless.
I even pulled an enclosed a little bit with the last gen 1. (24 ft v-nose) about 10k with everthing in it.
My gen 2 is much more suited to it because the HP, the gen 1 was just slow
Use a car trailer and a brake controller and dont sweat it.
03 cobra(QCKSNAKE)/6speed/[email protected](MIR)[email protected](Rockingham,NC) best 60ft 1.44
[email protected] w1.94 60ft-( [email protected] on slicks)
83GT [email protected] all moter 1.51 60ft.-sold
Fastest MT-82 COYOTE http://www.youtube.com/watch?v=GwUiEkCOTNE
jeremiahhussey is offline
post #7 of 17 Old 05-07-2009, 03:10 PM Thread Starter
Thunder5.0's Avatar
Cool, thanks.
post #8 of 17 Old 05-07-2009, 03:14 PM
The gen 1 came with a 351 with GT 40 intake and heads, right?
93AODGTvert is offline
post #9 of 17 Old 05-07-2009, 04:48 PM
Chris Wilson's Avatar
Yes, and Alum driveshaft / 4.10 gears.
04 Lexus ES 330
05 F250 King Ranch CC Diesel Shortbed FX4
Chris Wilson is offline
post #10 of 17 Old 05-07-2009, 04:49 PM
Also, I will suggest that if you are going to tow much with one of these you upgrade the transmission cooler. The Trans is the weak link in all of this beyond the short wheel base.
04 Lexus ES 330
post #11 of 17 Old 05-08-2009, 06:04 AM
LAPS 5.0LX's Avatar
[QUOTE=jeremiahhussey;8800474]Ive had 3 gen 1s and a gen 2.
My L went 15.40's in the 1/4 mile, and while not nearly as fast as the Gen2's, I never felt it was underpowered. We pulled my current boat home from Alabama with a buddy's 2001 Chevy dually with a 454, and I think my Lightning had better power on the freeway than the dually did(not saying much about Chevy I know..). Sounds like your a little spoiled with your current trucks power.
As far as the transmission goes, the gen1's came with the E4OD, I had mine for 60000 miles and towed a lot with it, a trans service every 20000 miles, fluid always looked good. Sold it with a 115000 miles, trans working good.
LAP
post #12 of 17 Old 05-12-2009, 01:47 PM
HIVOLTJ's Avatar
yeah, they're not as fast as the gen 2's stock, but drive another 1/2 ton small block truck (any brand) and then hop in a lightning, you'll appreciate how snappy they are. (drive a 454ss then a lightning for that matter, LOL)
Take the blower belt off of a gen2 and drive it if you want to know what a turd feels like
I wouldn't ever call a '93-95 Lightning "underpowered", I've left plenty of cars in the dust with a "WTF??" look on they're face.
'90 LX hatch 5.0/5spd = SOLD
'89 LX COUPE 5.0/5spd = SOLD
'94 Lightning #2978 = SOLD
'77 F-150 RCLB 2wd 408 cleveland in the works
HIVOLTJ is offline
post #13 of 17 Old 05-12-2009, 05:33 PM Thread Starter
Thunder5.0's Avatar
I Know they are only rated at 240 hp from the factory but when driving around with one tank full and the other empty, it's got some balls!
post #14 of 17 Old 05-14-2009, 08:58 PM
kbernal1016's Avatar
Trader Feedback: (27)
Remember one important thing: ford under-rates their motors.
Theyve done if for a VERY long time.
kbernal1016 is offline
post #15 of 17 Old 05-18-2009, 04:26 PM
90lx86svo's Avatar
I have towed an open trailer with my LX on it quite a bit and the only problem I had was going too fast in 100 F and overheated the trans (fluid comming out of the overflow) and it is still ok. I have since but a bigger cooler on it. I highly reccomend using a weight distributing hitch, they work much better than airbags because it puts weight on the front wheels of the truck. Be sure to use a trailer with brakes, a car on a dolly will tax the trucks brakes.
86 SVO
95 Lightning
90lx86svo is offline
post #16 of 17 Old 05-29-2009, 01:40 AM
most stock Gen 1's dyno at 190-200HP so the 240 is very close
95 Mustang 351 MM PHB/TA MM2 rear shocks and coilovers
17x10.5 sqaure
95Blitz is offline
post #17 of 17 Old 05-29-2009, 11:59 PM
gadget73's Avatar
I hate towing cars on a dolly. No tongue weight, and they tend to wander around at speed. I've also never had one with brakes, though I think they do exist. Trailers just tow nicer in my experience, especially when you're dealing with a trailer that has electric brakes. Nothing sucks more than being pushed down a hill by 5000 lbs on a tow dolly that doesn't want to track straight.
86 Lincoln Town Car
5.0 HO,FMS 1.72 roller rockers, BHPerformance ported E7 heads, Explorer intake, Hedman shorties, 2.5" dual exhaust with Impala tailpipes, traction lock with carbon-fiber clutches, 4 wheel disc brakes, ASP underdrive pulley
91 Mark VII LSC SE - triple black, all stock
gadget73 is offline
Trade 69 Mach for 1st Gen Lightning or cheap 2nd Gen dag302 Other Fords and Trades 1 03-29-2009 05:20 PM
NIB FMS 42lb Injectors, NIB Lightning 90mm Maf, Gen II to Gen I Maf Connector..Pics Z.A.P. Fuel System & Related 1 12-31-2007 07:31 AM
gen 1 lightning engine 89stk5.0 5.0/5.8 Engine Tech 2 12-24-2003 10:03 PM
towing w/lightning kyoshea Lightning/Harley Davidson F-150 10 02-28-2003 11:37 PM
Hey I saw SD in a Brand New 03 Lightning towing a body in white BTLFED GT & SOHC 7 09-12-2002 08:11 PM
