Distributor TFI question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 04-08-2009, 05:13 PM Thread Starter
Did all 93-95 Lightnings use a remote mounted TFI module?
Pantera5.0 is offline
post #2 of 8 Old 04-09-2009, 02:47 PM
Trader Feedback: (30)
Yes, the TFI module is mounted on the driver's fender.
1993 Black Lightning #2103
1995 White Lightning #585
1995 Black Lightning #184 Black hole where all my money goes!
1995 Mustang GT
madramper is offline
post #3 of 8 Old 01-02-2011, 11:58 PM
I believe some Ford vans used that setup, also, and there's be lots more of those if you're looking for a setup.
89 Linc Mk 7 LSC, 95 351, Ebrock hds, GT40, TF Stg 1 & 1.72, 70 MA, 30 inj's, 1-5/8 ceram short, 2-1/2" Dyno catbk, hi flo 180 stat & pmp, blue hoses & wires, 2 row rad, Taurus fan w/FAL VSC, trans filter & plate cool, 2700 stall, 3:55's, 17x8 Cobra & 255x50's, built 4R70W & Baum TCS
macx is offline
post #4 of 8 Old 01-03-2011, 08:48 PM
Do any of you know what color the TFI module would be? I have a Lightning computer for my upcoming swap and would like to plan ahead if possible.
thanks
tim
TS 95Cobra is offline
post #5 of 8 Old 01-04-2011, 12:48 AM
gray.
95 Mustang 351 MM PHB/TA MM2 rear shocks and coilovers
17x10.5 sqaure
95Blitz is offline
post #6 of 8 Old 01-04-2011, 08:42 AM
Thank you. I see by your sig you have a 95? Do you still run the SD computer with your AFRs and HO cam? How does it run? Are you pleased with the performance of the cam?
thanks again
tim
post #7 of 8 Old 01-04-2011, 01:04 PM
Yeah man no need to run MA. Here is a vid of the truck on the best run and with a blown head gasket and valve float at 5200.
ran a 7.59 It had a T-trim intercooled 60lb injectors, 2 step, line lock front and back, tweecer and a bunch other stuff. I like the cam at 4* NA it's a little low on torque but pulls hard up top.
17x10.5 sqaure
95Blitz is offline
post #8 of 8 Old 01-07-2011, 09:57 PM
Thanks! The cam was intstalled 4* advanced. The truck looks pretty darn fast.
tim
Mondo Bypass to Atmosphere Question kcowan Superchargers 16 04-18-2009 04:49 PM
98 Cobra ABS question BtwoG Road Racing/Auto X 1 03-25-2009 07:11 PM
question about choosing cams badass03gt GT & SOHC 16 03-24-2009 05:16 PM
Question on gas cap test, and fuel cell? slowfive0h95 94/95 Tech 2 03-23-2009 01:38 AM
Engine swap question NPI to PI MVK13 GT & SOHC 3 03-13-2009 06:46 AM
