Distributor Question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 17 Old 03-07-2009, 11:22 PM Thread Starter
dr doom's Avatar
On the 93-95 lightnings with the 351w, what year has the steel ring gear?
dr doom is offline
post #2 of 17 Old 03-08-2009, 03:58 PM
HIVOLTJ's Avatar
as far as I know, most of the late 93 to 95 blocks are roller cam READY, but they still had a flat tappet cam, so all the distributor gears should be cast iron
you should search over on www.nloc.net
'90 LX hatch 5.0/5spd = SOLD
'89 LX COUPE 5.0/5spd = SOLD
'94 Lightning #2978 = SOLD
'77 F-150 RCLB 2wd 408 cleveland in the works
HIVOLTJ is offline
post #3 of 17 Old 03-08-2009, 05:44 PM Thread Starter
dr doom's Avatar
Ill have to look over there, do you think the 351w that came in the f150 and e150 would have a steel ring gear?
dr doom is offline
post #4 of 17 Old 03-09-2009, 12:41 PM
HIVOLTJ's Avatar
you doing a roller cam swap or what?? I believe the 96 pickups and vans were the first with roller cams. If that's what you are doing, search "roller conversion" over on NLOC
HIVOLTJ is offline
post #5 of 17 Old 03-09-2009, 08:05 PM Thread Starter
dr doom's Avatar
418w with a solid roller cam
dr doom is offline
post #6 of 17 Old 03-10-2009, 12:42 PM
Trader Feedback: (30)
The 96 F250 351w came with a roller cam. All of the Lightnings were flat tappet. You can get the Ford Racing steel gear for like $25. That's what I did.
1993 Black Lightning #2103
1995 White Lightning #585
1995 Black Lightning #184 Black hole where all my money goes!
1995 Mustang GT
madramper is offline
post #7 of 17 Old 03-10-2009, 04:46 PM Thread Starter
dr doom's Avatar
Thanks guys for the info!
dr doom is offline
post #8 of 17 Old 04-06-2009, 09:21 PM
all of em
short dog is offline
post #9 of 17 Old 01-03-2011, 12:01 AM
Swapping gears is a trick. Even with a drill press I had a heck of a time drilling with that tiny drill bit.
If I had to do it again, I'd get my measurement and then take it to a good machine shop.
BTW the steel gear ("yellow stripe") you buy from Ford doesn't have any holes for hte pin.
You can find out about which vehicles came with a roller cam by looking up lifters for specific vehicles and motors in online catalogue's like O'Reilly auto parts, AutoZone, Rock Auto, etc.
89 Linc Mk 7 LSC, 95 351, Ebrock hds, GT40, TF Stg 1 & 1.72, 70 MA, 30 inj's, 1-5/8 ceram short, 2-1/2" Dyno catbk, hi flo 180 stat & pmp, blue hoses & wires, 2 row rad, Taurus fan w/FAL VSC, trans filter & plate cool, 2700 stall, 3:55's, 17x8 Cobra & 255x50's, built 4R70W & Baum TCS
macx is offline
post #10 of 17 Old 01-03-2011, 12:02 AM
Swapping gears is a trick. Even with a drill press I had a heck of a time drilling with that tiny drill bit. It wanted to flex and go crooked.
BTW the steel gear ("yellow stripe") you buy from Ford doesn't have any holes for the pin.
Would be worth it to find out which ones came stock with a roller cam and with the steel gear
and then buy one from a junk yard.
macx is offline
post #11 of 17 Old 01-03-2011, 12:07 AM
That would be why you take a punch and hammer and drive the roll pin out.
95 Mustang 351 MM PHB/TA MM2 rear shocks and coilovers
17x10.5 sqaure
95Blitz is offline
post #12 of 17 Old 01-03-2011, 06:11 AM
I didn't even bother. I just took it to a machine shop and paid like $10 to have it done. Way worth the time and aggrivation I saved!
1995 Mustang GT
post #13 of 17 Old 01-03-2011, 08:24 AM
Right, yeah - but the new gear doesn't have a hole for the pin and it's kind of hard to install the pin without a hole.
macx is offline
post #14 of 17 Old 01-03-2011, 08:28 AM
Now that's what I like - a man that understands "you gotta have a hole"
macx is offline
post #15 of 17 Old 01-03-2011, 11:19 AM
That's funny u can buy the gears with the holes already in them. Mmmm
17x10.5 sqaure
95Blitz is offline
post #16 of 17 Old 01-03-2011, 12:57 PM
The steel gear didn't have any holes in it when I bought mine about 5 years ago.
macx is offline
post #17 of 17 Old 01-03-2011, 01:31 PM
Mine did when I got it.
17x10.5 sqaure
95Blitz is offline
