speedometer - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 12-30-2008, 08:01 PM Thread Starter
speedometer
hi i just got a 1994 lightning and the speedometer ticks a little while accelerating... would i have to change the complete instrument cluster? also where can i find a dash kit? thanks
iggy2389 is offline
post #2 of 6 Old 12-31-2008, 06:42 AM
Don 95Vert's Avatar
The speedo is probably fine. May be a bad sensor in the rear axle housing. On mine it was corrosion where the sensor goes into the housing. I removed the sensor, then cleaned the area really well, replaced it and the speedo is now fine.
Don
95 Lightning - Slow
95 Convertible 357 turbo
10.5/135 @ 3800#
SCT Tuned
Don 95Vert is offline
post #3 of 6 Old 12-31-2008, 07:40 AM Thread Starter
speedometer
alright I'll try that out, thanks.
iggy2389 is offline
post #4 of 6 Old 12-31-2008, 09:43 AM
Check out the forums at www.nloc.net . You will get a lot more Gen 1 Lightning help there. Not talking anything away from The Corral, but you have a lot more Gen 1 owners to help you over there.
'94 Lightning 383ci w/Vortech S-Trim +too much to fit in the sig.
gn87gt2000 is offline
post #5 of 6 Old 01-01-2009, 09:32 PM Thread Starter
door panel
ok, do you know a website i can get a door panel for my 94 lightning?
iggy2389 is offline
post #6 of 6 Old 01-01-2009, 09:49 PM
Check here, and have them send you a free catalog. http://www.lmctruck.com/
Also check the classifieds on the NLOC.
