How do I get them to fit with out problems - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 13 Old 07-16-2008, 10:25 PM Thread Starter
istangn2's Avatar
Ok so I have a set of new lightning wheels I want to put on my 95 lightning I know there is a trick to getting them to fit but what is it.
istangn2 is offline
post #2 of 13 Old 07-17-2008, 09:09 PM
they have to be drilled out!
houseofpain11 is offline
post #3 of 13 Old 07-23-2008, 01:35 AM
DKH Racing's Avatar
Trader Feedback: (30)
What needs to be drilled out? The center hub or lug holes ?
Any brake clearence issues ?
Thanks.
DKH Racing is offline
post #4 of 13 Old 07-23-2008, 11:28 AM
BoostedEgo93's Avatar
nope just get a drill bit that is only 1/16th bigger than the hole in the second gen wheels. drill them and they should mount up with no issues. mine went on with no problems i sold them before i sold the truck thought g.l!
10 Fox Bodys And Counting...
BoostedEgo93 is offline
post #5 of 13 Old 07-23-2008, 05:06 PM
DKH Racing's Avatar
Hey thanks for replying, but you didnt really say what hole. Hub or lugs?
Thanks for the help boosted ego.
post #6 of 13 Old 07-23-2008, 10:06 PM Thread Starter
istangn2's Avatar
do i need any special lugnuts or will my stock 95 nuts work?
istangn2 is offline
post #7 of 13 Old 07-25-2008, 10:13 PM
Blurry94's Avatar
You will need the GEN 2 style lug nuts.
94 Lightning, Intercooled Vortech SQ
Blurry94 is offline
post #8 of 13 Old 07-25-2008, 11:41 PM Thread Starter
istangn2's Avatar
ok the new lugnuts wont fit the old studs, so now what do we do and i cant find a old style nut with a build in washer like the new style.
istangn2 is offline
post #9 of 13 Old 07-26-2008, 11:05 AM
Blurry94's Avatar
Other GEN 1 owners had mentioned getting the newer style lugnuts with the standard thread size. It may be something you have to order if you can't find them locally.
Blurry94 is offline
post #10 of 13 Old 07-27-2008, 07:00 PM
Hey I asked the same ? and this is what I was told.
The offset is slightly different. Doesn't cause a big problem. The grease cap for the front wheel bearings will hit the center cap unless you "dent" the grease cap (tacky) or use a 1/4" spacer on the front wheels. The rears are fine. The Gen 2 wheels are hubcentric and the hub size on the drums in rear and rotors up front are the same size. The Gen 2 wheels take a flat lugnut, not the tapered kind. The F-250 dualie lugnut from '96 and probably earlier have the lugnut you can use. If you go to a spacer for the front and the flat faced lugnuts you'll have to change the studs in the front rotors. Stock is 2 and 3/16th inch long and I used the Moroso 3" long ones to replace the stockers. The rear is fine unless you choose to use a spacer to move the rear wheels out a little bit. Then the same will apply for the rear studs as well. Stock rear studs are 1 and 13/16th inch long and I would think using the fronts in the rear would provide the necessary length increase to accomodate a spacer and the flat lugnuts They're just a bit harder to deal with to change.
giant2121 is offline
post #11 of 13 Old 07-27-2008, 10:57 PM Thread Starter
istangn2's Avatar
thanks thats just what i needed to know, great info and description
istangn2 is offline
post #12 of 13 Old 07-30-2008, 01:10 AM
Chanks7's Avatar
read this thread, this is how i did it:
http://www.nloc.net/vbforum/gen-1-li...-question.html
I ended up getting some black 1/2" washer style lug nuts off ebay and they look ok, you cant see them at all due to the recess i the wheels. Good luck!
94 GT bolt ons, 347 in the works
93 Lightning, Vortech S-trim
2003 Z71 Ext Cab LT
Chanks7 is offline
post #13 of 13 Old 08-06-2008, 10:23 PM
If you drill the holes out with a 17.5mm drill bit they will be correct.
SVT4CAM is offline
