1995 lightning questions? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 03-24-2008, 01:28 AM Thread Starter
k5boz's Avatar
I am a newby to the Lightnings. I bought a wrecked '95 for the engine & trans, to replace the injected 302 in my '79 bronco. I am trying to figure out some of the mods. Can someone help me out?
The ECM is maked BI00 & 4M16. The truck is Mass air. It has 24 lbs (blue top) injectors. It has 1.7 roller rockers. It has cast alum valve covers like a '91 mustang.
What is stock & what is not? I researched & found out these trucks are not Mass air. It has a Ford mass air sensor. Anyone know what kind/brand this conversion is? I really don't need it, is it worth anything?
The P.O. passed away & I bought the truck from his dad, so no help there.
Thanks guys.
k5boz is offline
post #2 of 10 Old 03-24-2008, 03:02 PM
95KBconv's Avatar
Interesting. From what I've read the BI00 EEC was for a 5.8L MAF truck (or bronco). Someone has swapped it in there, maybe DIY by repining the harness. Is there a chip on the EEC?
The valve covers are swapped also.
Sounds like you got some nice stuff.
Here's what a DIY swap would involve.
http://www.lasotaracing.com/html/ind...viewtopic_id=6
Ford had a kit that had 30 inj. , EEC, and a wiring harness. Pro-M made a harness too.
Have you found nloc.net. Tons of info over there.
1995 Ford Cobra w/IRS, white - Coyote swap with full MM front end in progress.
1994 Ford Lightning, red - HCI and Kooks in progress.
1993 Lexus LS400, grey - stock
2003 Infiniti M45, black - stock
95KBconv is offline
post #3 of 10 Old 03-25-2008, 02:20 PM
Constable's Avatar
Where are you located at??? I'd be interested in taking a look if you're local.
'01 Lightning #1910 [silver] - SOLD
'93 Notch [bright red] - SOLD
'95 Lightning #13 [black]- R.I.P.
'93 Notch [electric red] - SOLD
Constable is offline
post #4 of 10 Old 03-25-2008, 03:13 PM Thread Starter
k5boz's Avatar
I am near Memphis, TN.
k5boz is offline
post #5 of 10 Old 03-25-2008, 03:25 PM Thread Starter
k5boz's Avatar
Have you found nlocnet. Tons of info over there.
Thanks for the links. I have seen the & read the Ford conversion came w/ 30lbs injectors. I didn't know if the BI00 was the ECM they used or not. I saw someone mention it on NLOC, but could not find any details & fordfuelinjection-dot-com was down last night, so I could search there either.
I was planning on dropping this 351 into my '79 Bronco. I am running a '91 302 w/ a Ford motorsports harness & a A9L. Would what I have now run the 351 w/out problems.
Should I use the BI00 ECM. I am running a C6, & that ecm is for the E4OD. What would it act like running a non-ecm controlled trans?
Also your sig says you are running a '95 trans, what is special about a '95. What are the differences between the Lightning trans & the regular E4OD?
k5boz is offline
post #6 of 10 Old 03-25-2008, 05:23 PM
95KBconv's Avatar
When it comes to the SD to MAF conversion stuff, I'll defer to someone who knows alot more about it. I've only researched Lightning specific conversions (351/E40D).
This link has a little more info, but they are doing it to a 5.0 truck. I would think you are going to need a chip, but somewhere I think I saw the BIoo was for a 5.8....so. But nloc.net or a Bronco or truck forum would be the place to find out. Do some google searches on that processor and stuff.
http://www.fordmuscle.com/archives/2...sion/index.php
On the 95 transmission, the Lightnings upgrades on the transmissions as production progressed. The guy I bought my truck from had the transmission rebuilt and it included all of the latest upgrades (mostly for reliability I guess).
95KBconv is offline
post #7 of 10 Old 03-26-2008, 12:02 AM Thread Starter
k5boz's Avatar
Thanks, I posted up at NOLC, I'll see what turns up there.
k5boz is offline
post #8 of 10 Old 03-26-2008, 03:08 AM
Blame Canada!!!!!! I FAP for CANADA!
fapperDan's Avatar
Trader Feedback: (44)
the motorsports harness and a9l ecu will run the lightning 351 no problem its the same as a 302 just bigger
Banned!!!!!!!!!!!!!!!!
Canada loves me this I know, Cause the "Don" tells me so! Tumbleweeds we sell all day long, Ghost towns are coming so stay strong!
fapperDan is offline
post #9 of 10 Old 03-30-2008, 11:24 AM Thread Starter
k5boz's Avatar
Thanks, I wasn't sure if it would since this 351 has some mods.
k5boz is offline
post #10 of 10 Old 03-31-2008, 03:14 AM
fapperDan's Avatar
im in the proccess of puting a 393 in my car now and it will work
1995 GT 1st clutch replacement questions Inksplosive AL General Mustang Tech 18 06-06-2014 11:32 PM
1995 cobra engine compartment wiring/connector questions with pictures mustang2pt3 5.0/5.8 Engine Tech 1 03-26-2014 09:49 PM
1995 cobra tuning questions...mostly stock dgrobels 94/95 Tech 5 11-18-2011 04:13 PM
1995 cobra r questions on fox help needed stangsteve1993 Wheels and Tires 11 10-28-2004 11:19 AM
Questions about Johnny Lightning cool box for my car blown96bird Lightning/Harley Davidson F-150 1 06-24-2003 03:54 AM
