Advice please - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 03-13-2008, 04:15 PM Thread Starter
Trader Feedback: (18)
Advice please
I have a 93 f150 5.0 l, i have a 95 5.0 ho i want to put in it, how do i go about the mass air and firing order? thanx for any advice
wdstang is offline
post #2 of 6 Old 03-14-2008, 02:55 PM
I did an 89 bronco years ago and put in a 95 ho motor. i bought a motorsport mass air kit to do the swap. Im sure there are cheaper routes now if you do some 'net work. Ive seen people talk about swapping the proper mustang computer into the truck and adding the injector harness. Thats what the motorsport kit did but it was something like $600 bucks for the kit.
79 f-150 524" CJ
90 Mustang Gt
93 S-trim Ligntning
04 terminator FFR cobra Project
Bigblockbandit is offline
post #3 of 6 Old 03-16-2008, 02:15 AM
95KBconv's Avatar
I just throw this out here. Just playing around tonight and did this search. I don't know how correct their info is, I know that the VEX1 EEC is not a mustang eec as a couple of people thought it was. I have just read a little on the Lightning MAF swap with a VEX1. I is used because of the E4OD support. What tranny do you have?
http://www.ford-trucks.com/forums/22...onversion.html
Do some searches on google. There are some Bronco forums that do swaps also, sorta the same a a truck.
Here's a little more info too.
http://www.fordmuscle.com/archives/2...sion/index.php
1995 Ford Cobra w/IRS, white - Coyote swap with full MM front end in progress.
1994 Ford Lightning, red - HCI and Kooks in progress.
1993 Lexus LS400, grey - stock
2003 Infiniti M45, black - stock
95KBconv is offline
post #4 of 6 Old 03-17-2008, 11:58 AM Thread Starter
I have a aod, thanx for the info
wdstang is offline
post #5 of 6 Old 03-17-2008, 05:16 PM
95KBconv's Avatar
These guys would know using their products, I'm sure there's probably a cheaper junkyard harness or pin swap solution but I just have no idea.
http://www.massairsystems.com/E-TMAWH.htm
I've just focused on the 1st gen Lightning which is harder and more expensive I believe due to the E40D, wasn't a factory solution.
95KBconv is offline
post #6 of 6 Old 03-18-2008, 07:45 AM
http://www.nloc.net/
Might try the lightning club, there are a couple guys there that really know this stuff inside out. Fordfuelinjection.com used to have a lot of info on their site about conversions etc. not sure if its still around.
79 f-150 524" CJ
90 Mustang Gt
93 S-trim Ligntning
