lifter spider torque spec - Ford Mustang Forums : Corral.net Mustang Forum
 8Likes
  • 1 Post By AlexLTDLX
  • 2 Post By 96pushrod
  • 1 Post By GT80
  • 1 Post By Mark O'Neal
  • 1 Post By Enjoy_the_Ride
  • 1 Post By willyt
post #1 of 22 Old 12-26-2003, 03:09 PM Thread Starter
Viper Stang's Avatar
Question lifter spider torque spec
I don't seem to have the torque spec for the lifter holdown spider....can anyone provide it?
Thanks!
Viper Stang is offline
post #2 of 22 Old 12-29-2003, 04:06 AM
The torque specs for the valve tappet guide plate retainer bolts are 8-12 N - m, or 71-106 Lb-In, as per my Ford CD service manual.
When I replaced my lifters I just torqued mine to 15 foot lbs (12-15 ft lbs for valve cover), which now I realize turns out to be to much. The torque spec for the valve covers seemed comparable based on the size of the bolts and threads. The guide plate did not distort when I torqued it down so its probably just fine.
Is your head install complete?
94 Cobra, full Griggs, motor (overhaul in progress); 95 GT Conv, Explorer motor, Powerheads,TFS1,shorties,70mmTB,GT40intake,Quarter horse, CA emissions; 66 stock project car; 04 Silverado 4x4
GT Dan is offline
post #3 of 22 Old 12-29-2003, 08:54 AM
Michael Yount's Avatar
8-10 lb-ft; they're small bolts, doesn't take much torque to get the proper clamping force. Also, those and the block threads should be clean, and you should use loctite red on them. You definitely don't want the spyder coming loose on you.
Michael Yount - Charlotte, NC - 82 Volvo 242 - 6.2L; '17 Mazda3; '16 CrossTrek
Michael Yount is offline
post #4 of 22 Old 05-06-2019, 07:28 PM
120 inch pounds of torque which would be equivalent to 10 foot of torque if you dont have an inch pound wrench.
Shontz87 is offline
post #5 of 22 Old 05-06-2019, 08:09 PM
AlexLTDLX's Avatar
75 ft-lb
AlexLTDLX
AlexLTDLX is offline
post #6 of 22 Old 05-06-2019, 08:10 PM
AlexLTDLX's Avatar
Just kidding.
Laminar likes this.
AlexLTDLX
post #7 of 22 Old 05-06-2019, 08:58 PM
thadude's Avatar
How in the world did you come across this post, from 16 years ago, for your first post??
1993 Cobra #1282
thadude is offline
post #8 of 22 Old 05-06-2019, 10:57 PM
This thread is almost old enough to buy cigarettes haha.
GT80 and thadude like this.
1996 Mustang
347, 205 11R's, Box R Intake, Ported lower, custom comp cam, 42lb injectors, 255LPH, pro-m 80, 75mm Cheap-ass TB, 1 3/4 x 3in LT's, exhaust by me, A5 trans, 4.10
422WHP/456Ft/lb. Tuned using QH by Tony @ Tuners Inc.
96pushrod is online now
post #9 of 22 Old 05-06-2019, 10:57 PM
GT80's Avatar
Haha!! I bet Michael Yount feels old looking at this now. 16 years. Wow, I was....nevermind....
thadude likes this.
'88 Notch - BBK CAI, BBK X-pipe, Flowmaster catbacks, B&M shifter, Al driveshaft, SVE coilovers, MM full length SFCs, 5-lug conversion, rear discs, 2000 GT wheels.
GT80 is offline
post #10 of 22 Old 05-07-2019, 06:58 PM
Mark O'Neal's Avatar
Light to medium tight with a 1/4" drive.
Saleen414 likes this.
Mark O'Neal is online now
post #11 of 22 Old 05-07-2019, 09:35 PM
Enjoy_the_Ride's Avatar
I used grade 8 bolts so went with 12 ft lbs and red loctite
Enjoy_the_Ride is offline
post #12 of 22 Old 05-07-2019, 10:21 PM
thadude's Avatar
I'm sure the OP from 16 years ago will appreciate this info fellas, lets hope he hasn't been waiting this whole time
1993 Cobra #1282
thadude is offline
post #13 of 22 Old 05-08-2019, 03:09 AM
I am not one to take chances....
thadude likes this.
post #14 of 22 Old 05-08-2019, 09:10 AM
No OP gets left behind.
thadude likes this.
post #15 of 22 Old 05-08-2019, 09:31 AM
red loctite and good-n-tight
b--rad is offline
post #16 of 22 Old 05-08-2019, 12:16 PM
willyt's Avatar
.75 ugga duggas
thadude likes this.
88GT with the 5.slow
willyt is offline
post #17 of 22 Old 05-08-2019, 04:31 PM
tmoss's Avatar
Trader Feedback: (48)
not red, blue loctite - I torqued mine and it still backed off - lost a cam due to it......
Tom Moss
tmoss is offline
post #18 of 22 Old 05-08-2019, 05:14 PM
Trader Feedback: (41)
If blue didn't work why use it again?
I would use red
stangjumper is offline
post #19 of 22 Old 05-08-2019, 05:45 PM
Saleen414's Avatar
I have never used a torque wrench or lock tite on those bolts. Dozens and dozens of those engines without ever having a problem. Maybe I am Lucky...
26 X 8.5 Hoosier
Saleen414 is offline
post #20 of 22 Old 05-09-2019, 05:10 PM
tmoss's Avatar
I would use red
I didn't use blue, but should have in hind sight
Tom Moss
tmoss is offline
post #21 of 22 Old 05-10-2019, 03:56 PM
Weld it.
post #22 of 22 Old 05-10-2019, 03:58 PM
tmoss's Avatar
Weld it.
Tom Moss
tmoss is offline
Upper Intake Torque Sequence & Stud/Nut Spec? TrickVert 5.0/5.8 Engine Tech 2 05-05-2008 08:49 AM
car wont move? 87blustang 5.0/5.8 Engine Tech 12 04-25-2008 01:43 AM
Replacing the pinion seal: Torque spec and other q's. Terrible Juan General Mustang Tech 4 01-03-2005 06:50 AM
What's the Torque spec for the Lifter Retainer Plate??? BaD Karma 5.0/5.8 Engine Tech 2 06-26-2002 10:41 PM
Drop in RPM's at each shift? slosvt GT & SOHC 41 04-06-2002 01:01 PM
