How Much Oil? - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By theconductor
post #1 of 12 Old Yesterday, 07:18 PM Thread Starter
How Much Oil?
Question;
I'm running a Moroso 7 quart pan with an oil fed Vortech V1. Would I want to put more than 7 quarts in?
My dipstick doesn't read any oil at 7 quarts, presumably because I had to put a few extra bends in the tube to fit with the new headers. I'm looking for a good base before I start shortening the tube to get a reading.
Thanks.
theconductor is online now
post #2 of 12 Old Yesterday, 07:21 PM
No, 7 total
630-462-3978 Shop Direct
877-723-5487 Shop Toll-Free
TONS of Build Photos Ck at
Make sure to sign up for
strokeme is online now
post #3 of 12 Old Yesterday, 08:44 PM Thread Starter
Originally Posted by strokeme View Post
No, 7 total
Thank you. And thank you for the motor!
Str8ballar likes this.
post #4 of 12 Old Today, 12:26 AM
nvrstuk's Avatar
So the 7 qt pan only holds 6 1/2 qts then? No allowance for the extra oil in the filter?
Just wondering as I am running a 7 qt Ford Motorsports pan and they specifically stated to add another 1/2 qt to the pan on initial startup for the extra amount the filter would hold. So 7 1/2 qts total.
Interesting how different manufacturers "rate" things...
Strrrrroker powered 460sbf, 24 forward gears, 4 reverse, OBA for ARB lockers frt/rear, 35 spline RCV chrome alloy axles frt & rear, FF rear, all custom-everything but the windshield frame and glass is custom, ...
nvrstuk is offline
post #5 of 12 Old Today, 12:41 AM
Doesn't the fl1a hold a quart? So I always thought with a 7 quart pan the system would hold 8 quarts.
bucho65-2 is offline
post #6 of 12 Old Today, 06:50 AM
Saleen414's Avatar
A FL1A will hold about half a qrt of oil. I always prefill the oil filter before installing it on the engine and they take about 1/2 a qrt to fill.
Stand a qrt of oil next to a FL1A and you will see why it will not fit in the filter.
26 X 8.5 Hoosier
Saleen414 is online now
post #7 of 12 Old Today, 07:16 AM
I have a 7 quart Moroso pan that I also received from woody. With oil in the filter I use a hair more than 7 quarts total. Realistically even if you’re at 7 total, including what’s in the filter you should be fine.
I use the Moroso dipstick that’s meant for the pan and fill it to just under full. Works good for me.
1996 Mustang
347, 205 11R's, Box R Intake, Ported lower, custom comp cam, 42lb injectors, 255LPH, pro-m 80, 75mm Cheap-ass TB, 1 3/4 x 3in LT's, exhaust by me, A5 trans, 4.10
422WHP/456Ft/lb. Tuned using QH by Tony @ Tuners Inc.
96pushrod is online now
post #8 of 12 Old Today, 07:26 AM
Enjoy_the_Ride's Avatar
I run 6 quarts including the filter in my 7 quart Moroso pan
Enjoy_the_Ride is offline
post #9 of 12 Old Today, 08:58 AM Thread Starter
Originally Posted by 96pushrod View Post
I have a 7 quart Moroso pan that I also received from woody. With oil in the filter I use a hair more than 7 quarts total. Realistically even if youíre at 7 total, including whatís in the filter you should be fine.
I use the Moroso dipstick thatís meant for the pan and fill it to just under full. Works good for me.
Do you have a link for that? The Moroso website only has universal dipsticks.
post #10 of 12 Old Today, 08:38 PM
Saleen414's Avatar
I run 6 qrts with filter in my Canton 7 qrt Drag Race oil pan. I do not use a dip-stick.
26 X 8.5 Hoosier
post #11 of 12 Old Today, 08:52 PM
Cougar5.O's Avatar
I set up my dipstick to read full at 7 quarts, but I fill with 6 quarts in my Canton road race pan.
I had a dipstick, had to remove it due to headers. I'd like to have a quality flexible shaft dipstick, but I can't find one long enough.
'87 20th Anniversary Cougar - 427W. AFR220's, Supervic, RCI 1 3/4" mid-length, 250ish .6" cam, Holley HP tuned.
Cougar 7.0
Cougar5.O is online now
post #12 of 12 Old Today, 09:13 PM
The moroso 25971 is what I use. “Full” is when there is about 7 qts in the pan.
1996 Mustang
