Timing cover corrosion repair? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 08-13-2019, 09:01 PM Thread Starter
Cutlass327's Avatar
I was cleaning this engine up, and the drain behind the water pump for the timing cover was plugged, and there is corrosion. I took my wood handled chip brush and was hitting against the deepest pit, and it dented out on the back side. Is this safe to repair with just silicone or JB Weld? Or should I bite the bullet and buy new?
And off this topic, are these numbers piston fit numbers stamped into the oil pan gasket surface?
Sent from my VS995 using Tapatalk
78 CJ5 with 86 5.0HO DX3 ecu from 88 MK VII
Cutlass327 is offline
post #2 of 5 Old 08-13-2019, 09:34 PM
JV106's Avatar
Personally I’d replace it. Get a new bolt kit too.
JV106 is offline
post #3 of 5 Old 08-13-2019, 09:38 PM Thread Starter
Cutlass327's Avatar
Anyone ever use one of these?
Was looking at reviews for the older version, and there were comments about drilling out flashing, timing pointer hole not tapped, seemed softer... Makes me wonder on these ones.
If you recommend one, hopefully it is from Summit as that's about a 45 min drive to pick it up tomorrow.
post #4 of 5 Old 08-14-2019, 01:02 AM
Allstar is just the name. I have used probably 1000 or so of these and cant recall a time where I didnt use one because of an issue. If you want to grind out the casting flash in the water ports have at it, but it wont make one bit of operational difference.
630-462-3978 Shop Direct
877-723-5487 Shop Toll-Free
TONS of Build Photos Ck at
Make sure to sign up for
strokeme is online now
post #5 of 5 Old 08-14-2019, 01:06 AM
Same cover, same manufacturer
https://lmr.com/item/LRS-6019B/83-93...yABEgLVbPD_BwE
