302 gt40 Heads 0n3 Or 351cam and heads. - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By taco
post #1 of 8 Old 08-12-2019, 07:26 PM Thread Starter
turbotoys22's Avatar
So at work talking about builds ? And budget building 302 on-3 it.Or 351 with a set of heads keeping the cost down .No adding turbo to 351 just what's yours chioce.
351 gives you more room to grow .Is probably easier to maybe work on and raw power.And can allway
On3 plenty to break the stock block and a nice quite sound .
So I think this is a good ? What whould you guys do max power is not necessarily the key best street light and fun car to drive with the least amount of problems doing it for $3500.or less.
turbotoys22 is offline
post #2 of 8 Old 08-12-2019, 08:25 PM
351 with gt40 heads and on3 turbo.
The 302 block is too weak.
tjm73 likes this.
taco is offline
post #3 of 8 Old 08-12-2019, 10:16 PM
Ssp 363's Avatar
302 with the on 3 turbo kit.
92 ssp mustang coupe
Ford racing boss 427 540hp 555tq 1/4 mile 11.07 @127
AFR205cc heads w/58cc chambers
Trickflow R intake with box upper/90mm throttle body
Ssp 363 is offline
post #4 of 8 Old 08-13-2019, 07:37 AM Thread Starter
I say 351 buy a decent re built short block for about $2800. With balencer .That's close to the same as on 3 kit with extras. Give or take a few hundred here on either side .That 351 should run flawlessly with a great amount of street power and be quick of the street light .
post #5 of 8 Old 08-13-2019, 08:12 AM
A 351W with GT40 heads (if you already have them, don't hunt for them with this project) will make an easy 300 hp at the crank. 8 psi from an On3 will make that into 450 hp and the block will be plenty strong at that level. Put almost any decent aftermarket aluminum head on it and you will jump at least 50 N/A hp and you end up well over 600 hp on 12 psi with pretty much the same reliability.
tjm73 is offline
post #6 of 8 Old 08-13-2019, 10:59 AM Thread Starter
Well I have a spare set with 1.7 rockers.So if I'm pulling heads on a 302 to put arp and head gaskets I'm sure as heck throwing on some 40s.
post #7 of 8 Old 08-13-2019, 02:14 PM
Kind of difficult to answer with no goals, application or defined budget.
If it's strictly about power for the money a budget turbocharged 302 will make more than a budget naturally aspirated 351.
bluemp301 is offline
post #8 of 8 Old 08-13-2019, 04:16 PM
Since you have them, use them. You can probably hit 1 hp/cubic inch naturally aspirated (in boost friendly form). So let's say you have 350 crank hp. Add a mild very pump gas friendly 8psi and boom you are in the 550 horsepower neighborhood for reasonable money. With iron GT40's (from what I've read) conservative is the path to longevity. Conservative boost, compression, ignition, and safe fuel delivery, ie...don't run near the edge, and you will make good power without lifting the heads.
tjm73 is offline
