5.0 rocker arm movement/noise - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By indy2000
post #1 of 15 Old 06-16-2019, 03:48 PM Thread Starter
I heard loud knocking under driver side valve cover, I took it off and noticed one rocker has a lot of movement where the rest don’t.
Things I’ve checked:
-push rod is not bent (I.e. it rolls smooth across table)
-lifter (I was told the way to test a lifter is to see if it can be pushed in by hand- which it can’t
-valve isn’t stuck. I see movement when I let the engine run without valve cover.
Thanks in advance and happy Father’s Day to the mustang Dads!
90 lx daily driver (Project driver)(SOLD)
94 cobra bone stock (SOLD)
92 LX Vert project
"Run What Ya Brung"
90lxhatch93 is offline
post #2 of 15 Old 06-16-2019, 10:37 PM
midnightlaundry's Avatar
Any pushrod contact on the rocker like this?
midnightlaundry is online now
post #3 of 15 Old 06-16-2019, 11:07 PM Thread Starter
Well if you mean by the silver indentation, maybe a little but not that bad. But I swapped the rocker with one that didnít move and then it still has movement.
92 LX Vert project
"Run What Ya Brung"
post #4 of 15 Old 06-16-2019, 11:57 PM
indy2000's Avatar
'a little' ??
well, keep running it until it self clearances, the noise will eventually go away.
TomV likes this.
indy2000 is offline
post #5 of 15 Old 06-17-2019, 01:02 AM
Can you explain what you mean by movement? Is the arm really easy to compress against the pushrod/lifter? If so, sounds like you have a bad lifter. You can try to take it apart and clean it or just replace it. Unless you have a sonic cleaner I would just replace it. If they are stock style lifters make sure the body of the new one matches the style you take out. There are 2 different body styles for OEM lifters
Turbo Teal 95 GT 5 speed, Creb Engineering 331 10.2:1, TFS 190 56cc 11R heads, Victor 5.0 intake, F-cam, Siemens 80s, HP hotside, custom coldside, Moates QH T4M2 custom tune by me, 91 octane 560HP 602TQ
***E85 coming soon***
Dwain is offline
post #6 of 15 Old 06-17-2019, 10:55 AM Thread Starter
By movement, itís like there is space between the rocker and either the valve or pushrod and it allows movement in that direction as well as side to side.
post #7 of 15 Old 06-17-2019, 10:58 AM Thread Starter
Originally Posted by indy2000 View Post
'a little' ??
Is this sarcasm or serious? Lol. The engine has been sitting for awhile, I thought about putting stop tick or transmission fluid in the oil and seeing if it clears up; but I hate to drive it like that. You know everything is looking at it thinking: "man what a piece of junk that old mustang is!" Plus thereís concern for dropping a valve and ruining the engine
92 LX Vert project
"Run What Ya Brung"
post #8 of 15 Old 06-17-2019, 01:03 PM
Since you had the valve cover off, with the rocker in the 'up' position see if there is up/down play in the push rod.
Telling us the motor has sat for a long while makes me wonder if a lifter isn't pumping up now.
I'm guessing that this issue did not exist when the vehicle/motor was set aside. Is this a bad assumption?
stock block 347 w Bullet Forged flat top pistons, TW170 p&p heads, comp 35-775-8 cam, approx 9.6:1 compression, 72mm rear mount turbo, injector clinic 650h injectors, CircleD 2800 stall converter, Lentech valve body.
Dono2 is offline
post #9 of 15 Old 06-17-2019, 07:13 PM
indy2000's Avatar
if the pushrod is hitting the rocker, there is something wrong, ie wrong rocker, poor quality?
indy2000 is offline
post #10 of 15 Old 06-17-2019, 08:51 PM Thread Starter
Itís not hitting the rocker no. The loose rocker rests on the pushrod and moves when itís supposed to.
92 LX Vert project
"Run What Ya Brung"
post #11 of 15 Old 06-17-2019, 08:56 PM
what head? What rocker arm?
630-462-3978 Shop Direct
877-723-5487 Shop Toll-Free
TONS of Build Photos Ck at
Make sure to sign up for
strokeme is offline
post #12 of 15 Old 06-17-2019, 09:28 PM
indy2000's Avatar
you admitted there contact like in the picture?
which is it, contact or not?
indy2000 is offline
post #13 of 15 Old 06-18-2019, 12:58 PM Thread Starter
Stock and stock
92 LX Vert project
"Run What Ya Brung"
post #14 of 15 Old 06-18-2019, 12:59 PM Thread Starter
No
92 LX Vert project
"Run What Ya Brung"
post #15 of 15 Old 06-18-2019, 01:58 PM
stock e7te's??
