446 cid windsor - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 18 Old 06-14-2019, 12:14 PM Thread Starter
446 cid windsor
Would anyone have a round about idea what a 446 cid windsor would make power wise?
Dart SHP 4 bolt mains block
4.125 bore
4.170 crankshaft
6.250 eagle h-beam rods
Ross 14:1 compression custom pistons
AFR 220 Renegade Heads 58cc
282/292 @ 50 duration 725 Lift 114 Lobe sep
Super victor intake
MSD Crank trigger and ignition
1100 cfm prosystems dominator
BigPhil85 is offline
post #2 of 18 Old 06-14-2019, 12:28 PM
750 HP
DE4DLY1 is offline
post #3 of 18 Old 06-14-2019, 01:59 PM
assuming no nitrous or forced induction, what cam is that, and why was it chosen?
'92GT, 427" and '93 "LXVO" coupe
toddturbo is offline
post #4 of 18 Old 06-14-2019, 02:10 PM Thread Starter
Yes, it will be nitrous fed, just want to know what power it would make without nitrous
post #5 of 18 Old 06-14-2019, 02:32 PM
I actually have a desktop dyno program, I can run it through just for ####s.
E85 combo?
1996 Mustang
347, 205 11R's, Box R Intake, Ported lower, custom comp cam, 42lb injectors, 255LPH, pro-m 80, 75mm Cheap-ass TB, 1 3/4 x 3in LT's, exhaust by me, A5 trans, 4.10
422WHP/456Ft/lb. Tuned using QH by Tony @ Tuners Inc.
96pushrod is offline
post #6 of 18 Old 06-14-2019, 02:46 PM Thread Starter
No, VP C23
post #7 of 18 Old 06-14-2019, 04:02 PM
Saleen414's Avatar
If you can't make over 850 N/A you are doing it wrong
26 X 8.5 Hoosier
Saleen414 is offline
post #8 of 18 Old 06-15-2019, 07:01 AM
With AFR 220's and a Super Vic? Not happening.
Sprayn383 is offline
post #9 of 18 Old 06-15-2019, 02:42 PM
your N/A HP is usually going to be disappointing because of the nitrous tune up. At least that has been my experience. Maybe 675-700?
post #10 of 18 Old 06-15-2019, 07:10 PM
Saleen414's Avatar
Sure it can. 15 years ago I made 620 HP N/A with a 347 Victor Jr heads and a Victor Jr Intake with a smaller nitrous cam with less compression. With an extra 100 cid and extra compression, better heads, intake and cam it is a walk in the park.
26 X 8.5 Hoosier
post #11 of 18 Old 06-16-2019, 01:42 PM
rob
rob's Avatar
Trader Feedback: (23)
With 13:1 454 Windsor, afr 225, super victor we made 707 at high 6k low 7k, which is right where the math said it would make. Also set up for spray.
I would guess yours will make a few more. How about 720?
rob is offline
post #12 of 18 Old 06-17-2019, 11:01 AM
Why stop at a 4.125" bore, open her up some more and unshroud the valves.
AL P is offline
post #13 of 18 Old 06-17-2019, 11:41 AM Thread Starter
I would go bigger than 4.125 bore, but already have pistons for that bore.
post #14 of 18 Old 06-17-2019, 02:23 PM
Cougar5.O's Avatar
Gonna say 700-750HP, seems others are in that range also.
'87 20th Anniversary Cougar - 428W - Cougar 7.0
2012 GT500
Cougar5.O is offline
post #15 of 18 Old 06-18-2019, 04:56 AM
wytwolf's Avatar
Lots
wytwolf is offline
post #16 of 18 Old 07-10-2019, 05:45 PM Thread Starter
Just received my custom pistons from Ross and calculated my compression ratio, it should be somewhere around 14.64:1, plan on running a fogger with 250 shot with nitrous 120 fuel, my goal is 5.50's or better in the 1/8 mile, any opinions?
post #17 of 18 Old 07-10-2019, 07:37 PM
Saleen414's Avatar
Would need to know weight of car, trans and gearing and tire size/type
26 X 8.5 Hoosier
post #18 of 18 Old 07-10-2019, 07:41 PM Thread Starter
3400lbs, 4.30 gear, powerglide, 275 radial
