How to determine 11R 205 cc size? - Ford Mustang Forums : Corral.net Mustang Forum
 3Likes
  • 1 Post By KY408Fox
  • 1 Post By strokeme
  • 1 Post By b--rad
post #1 of 5 Old 05-19-2019, 08:42 PM Thread Starter
There is a used set of 11R 205 heads, but the guy doesnít know what cc the combustion chambers are. Is there any identification numbers I could use to figure out if they are 56 or 66ccís?
Dieselpunk is offline
post #2 of 5 Old 05-19-2019, 09:00 PM
KY408Fox's Avatar
The cc size is machined right in the head
File Type: jpg AD057C66-5851-4FE5-A5D9-5AA3FF332062_1558314029479.jpg (48.1 KB, 49 views)
Dieselpunk likes this.
KY408Fox is offline
post #3 of 5 Old 05-19-2019, 09:43 PM
It's on the exhaust face
630-462-3978 Shop Direct
877-723-5487 Shop Toll-Free
TONS of Build Photos Ck at
Make sure to sign up for
strokeme is online now
post #4 of 5 Old 05-21-2019, 01:30 AM Thread Starter
Thank you 😊
post #5 of 5 Old 05-21-2019, 01:31 PM
get some liquid... a syringe... piece of Plexiglas with a hole drilled in it... and i bet you could know for sure then...
wytwolf likes this.
b--rad is offline
will these pistons fit 205 11r heads ??? 408wf1 5.0/5.8 Engine Tech 8 03-29-2019 07:23 PM
how to determine rotors & brake pad size the green machine General Mustang Tech 2 06-18-2012 10:26 PM
AFR 205 combustion chamber size? Riley97 5.0/5.8 Engine Tech 0 03-09-2004 01:28 PM
