Siemens deka 55# injectors are these high or low imp - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 05-16-2019, 07:09 PM Thread Starter
Trader Feedback: (39)
I have had these for 10 years cant remeber if they are high or low imp
Can anyone tell by looking at them
File Type: jpg received_505939529942669_1558048104096.jpg (38.5 KB, 15 views)
File Type: jpg received_2329053480641988_1558048124400.jpg (88.3 KB, 14 views)
93sn8k is offline
post #2 of 10 Old 05-16-2019, 09:11 PM
Trader Feedback: (41)
Check the resistance with a multi meter.
stangjumper is offline
post #3 of 10 Old 05-16-2019, 09:27 PM
A google search says the 3102 are low.
1996 Mustang
347, 205 11R's, Box R Intake, Ported lower, custom comp cam, 42lb injectors, 255LPH, pro-m 80, 75mm Cheap-ass TB, 1 3/4 x 3in LT's, exhaust by me, A5 trans, 4.10
422WHP/456Ft/lb. Tuned using QH by Tony @ Tuners Inc.
96pushrod is offline
post #4 of 10 Old 05-16-2019, 10:28 PM Thread Starter
I do have an on board PMS with the
low imp driver
But again was not sure what they were
Thanks for the help...
93sn8k is offline
post #5 of 10 Old 05-16-2019, 10:54 PM
indy2000's Avatar
measure it!
dont trust interweb
indy2000 is online now
post #6 of 10 Old 05-17-2019, 04:49 PM Thread Starter
Originally Posted by indy2000 View Post
measure it!
dont trust interweb
What do you mean by that ...measure it ?
93sn8k is offline
post #7 of 10 Old 05-17-2019, 05:03 PM
indy2000's Avatar
Hi imped =x
lo imped=y
when you measure, you will get either a y or x value
post #8 of 10 Old 05-21-2019, 01:09 AM Thread Starter
How do i measure them ?
i have never done this nor has anyone around me ...
93sn8k is offline
post #9 of 10 Old 05-21-2019, 07:16 AM
You touch the leads of the ohmmeter to the leads on the connector. High imp will typically be 10 ohm or more. Low imp less than 4, most likely lower.
1996 Mustang
post #10 of 10 Old 05-24-2019, 01:14 AM Thread Starter
Thanks for the info
93sn8k is offline
For Sale Siemens Deka 80 lb high impedance injectors W/ PMAS 80mm MASS AIR METER CATALYST Fuel System & Related 9 02-15-2012 07:44 PM
For Sale 60 lb Siemens Deka high imp. injectors with matching 80 mm mass air clairstewart Fuel System & Related 5 10-24-2011 10:36 PM
Siemens Deka 60# High imp injectors autosay97 Fuel System & Related 3 05-03-2008 07:12 PM
YOUR ONE STOP PERFORMANCE SHOP FOR ALL YOUR FUEL NEEDS.....READ WITHIN!!!!! Muscle Motors Performance Fuel System & Related 40 03-25-2005 10:25 PM
YOUR ONE STOP FUEL SOURCE......FUEL INJECTOR BLOWOUT!!!!!!! Muscle Motors Performance Fuel System & Related 17 05-20-2004 04:46 PM
