Cobra 39lb injectors in 351w - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 05-16-2019, 04:04 AM Thread Starter
10SEC93GT's Avatar
I've heard some people say that's it no problem and others say dont use them. I got a set really cheap and sold my Ford 42s bc somebody offered me more money than I could turn down...I'd like to know if it works, I'm sure people here have done it and have real world experience, thanks
10SEC93GT is offline
post #2 of 2 Old 05-16-2019, 10:26 AM
indy2000's Avatar
if it was designed for two intake valves, then the spray pattern is different then what you need
some will say its fine and some will say not
injectors are rather important, so why waste money on a unknown, buy new known injectors..........siemen deka 80s, are one of the most reliable and plenty big enough to grow your hp without needing to change them
indy2000 is offline
FUEL PUMP FLOW TESTS REVEALED! (and some other useful injector vs horsepower info) KBtech Superchargers 40 07-31-2017 08:45 AM
39lb Cobra Injectors and other stuff kevinflick03 Fuel System & Related 3 02-10-2010 12:00 AM
Fitting a 351 Windsor under a stock hood SPOOLIN5.8 5.0/5.8 Engine Tech 30 05-26-2007 01:05 PM
302 to 351 swap? IJUST8UR8 5.0/5.8 Engine Tech 7 01-24-2007 03:35 PM
03 cobra aftercooler box on a 99gt superGT99 GT & SOHC 7 07-23-2002 11:22 AM
