Valve seals sitting at top of valve with triple springs - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By Ed Curtis
post #1 of 15 Old 05-11-2019, 12:33 AM Thread Starter
My engine is burning oil while hot. But, It has less than 2000km on it.
I pulled the valve covers. Noticed that 4-5 valve seals are sitting at the top of the valve.
I am running triple valve springs. Not sure if they're hitting the inner spring?
Are there thinner valve seals? Can anyone recommend a good set?
I can't afford to pull the heads for a machine shop and have my car immobile. Someone totaled my daily driver.
Will valve seals cause an engine to burn oil while hot? Or, Is it more so after it's been sitting?
Boss block 308, stage 3 canfields, spyder intake, 90mm tb, 96lb msds, sds inj, hanlon tko, tti race kit t-76 q-trim, 00r wheels+brakes, steeda 5-link. Aiming for 700rwhp.
mitchwolos is offline
post #2 of 15 Old 05-11-2019, 01:34 AM
The inner spring is pulling the valve seal off the guide. I assume you mean a dual spring with a flat wire damper?
630-462-3978 Shop Direct
877-723-5487 Shop Toll-Free
TONS of Build Photos Ck at
Make sure to sign up for
strokeme is online now
post #3 of 15 Old 05-11-2019, 03:26 AM Thread Starter
I have no idea. The machine shop said they were triple springs. It's a solid roller cam.
How do I prevent this? Can I buy thinner valve seals?
How possible is it that the burning oil is coming through the valve guides while it's running?
post #4 of 15 Old 05-11-2019, 08:06 AM
Old timer
Ed Curtis's Avatar
What valve stem diameter?
What guide boss diameter?
There are plenty of seals that can clear.
Quote Mark O'Neal: "Virtually every customer I have has the same first interest. That is what is the lowest price he can pay. People like myself, Ed and very few others on this board have spent decades learning what we know.....and y'all want that knowledge for free....and you'll take the parts for free as well."
Nil Satis Nisi Optimum
Ed Curtis is offline
post #5 of 15 Old 05-12-2019, 01:18 AM Thread Starter
Canfield heads. OEM guides for the head. Can't seem to find info online. Can't afford downtime to tear it apart and measure. It's my only car at the moment.
post #6 of 15 Old 05-12-2019, 05:04 AM
Old timer
Ed Curtis's Avatar
FTI Viton Valve Seals - 343 x 531 - FlowTech Induction
mitchwolos likes this.
post #7 of 15 Old 05-15-2019, 10:12 PM
Enjoy_the_Ride's Avatar
damn, when did valve stem seals get so expensive?
Enjoy_the_Ride is offline
post #8 of 15 Old 05-17-2019, 01:47 AM Thread Starter
Thank you Ed!
post #9 of 15 Old 05-18-2019, 09:51 PM Thread Starter
Can anyone recommend a spring compressor that will work on the car? I can't afford to be taking the heads off. Thanks.
I already ordered the air fitting to go in the spark plug hole.
post #10 of 15 Old 05-18-2019, 10:40 PM
Are the heads stud mount? The LSM spring compressor was worth every penny I spent on it...I wish it was the first spring compressor I ever purchased.
bsfguy is offline
post #11 of 15 Old 05-18-2019, 11:09 PM Thread Starter
Yep. Stud mount currently. Shafts soon. But, I guess I can always take the shafts off and re-use the studs if I need them later.
post #12 of 15 Old 05-21-2019, 08:22 AM
Laminar's Avatar
I had good results with the Summit valve spring compressor.
https://www.summitracing.com/parts/SUM-906784
mikaelvroom.com
1969 Cougar | 1997 M3-5.0
Laminar is offline
post #13 of 15 Old 05-22-2019, 03:13 AM Thread Starter
It will work to service all 16 valves with the engine installed in the car?
post #14 of 15 Old 05-22-2019, 06:58 AM
Saleen414's Avatar
You do know that you can rent a car for $25 per day right? And if someone totaled your daily driver, then their insurance would cover putting you into a rental until there was a settlement of the case.
26 X 8.5 Hoosier
Saleen414 is offline
post #15 of 15 Old 05-31-2019, 03:28 AM Thread Starter
#1 no garage
#2 no time
#3 #### insurance in Canada
Thanks for your input.
what valve seals with double valve springs? rampage2587 5.0/5.8 Engine Tech 2 09-29-2014 06:31 PM
Manley Nextek Valve springs, (new) part#22430, Andy Rowley Windsor Engine Parts 13 01-13-2008 10:09 PM
2V used Comp 262AH cams, new Crower springs, new valve seals - $500 shipped nickmckinney Modular Engine Parts 8 12-12-2007 05:35 PM
New convert top Install?????????? atann76 The Body Shop 27 06-29-2005 07:40 PM
IMPORTANT!!! Possible new head option! gr8yte SVT & DOHC 57 08-25-2003 11:14 AM
