What distributor do you use 351w EFI swap in 1993 mustang - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By 93sn8k
post #1 of 16 Old 05-04-2019, 10:53 AM Thread Starter
Trader Feedback: (39)
What TFI module do you use
5.0 or 5.8 off stock distrib ?
NO MSD....
Autozone distrib part #
Or
Advance auto #
Or
Oriely auto parts #
Thanks in advance
93sn8k is offline
post #2 of 16 Old 05-04-2019, 11:20 AM
AtomicCoupe's Avatar
Motorcraft DY1284- doesn’t matter 5.0 or 5.8.
Stock block 306, V1 T-trim, AFM B-451 cam, TFS Twisted Wedge, Holley Systemax, A1000, Snow Meth, TKO 600, Team Z, Strange, MM, Lakewood and Moser helps me go forward fast.
AtomicCoupe is offline
post #3 of 16 Old 05-04-2019, 11:21 AM
Oh ya, you say no MSD...I just bought a Motorcraft as a backup....had to swap back to my 6 year old MSD module, on the side of the road, to make it back home.
post #4 of 16 Old 05-04-2019, 02:01 PM
408wf1's Avatar
i had good luck with msd dizzy on my 408 and 302 both will blowers
408wf1 is offline
post #5 of 16 Old 05-04-2019, 02:17 PM
Ssp 363's Avatar
I have been running a mallory distributor i got from summit racing since 2014 with no issues but i pretty sure that part is discontinued now.The msd unit went out in just a few hundred miles.
Tfi module from O'riellys auto it has been working good so far.
92 ssp mustang coupe
Ford racing boss 427 540hp 555tq 1/4 mile 11.07 @127
AFR205cc heads w/58cc chambers
Trickflow R intake with box upper/90mm throttle body
Ssp 363 is offline
post #6 of 16 Old 05-04-2019, 11:33 PM Thread Starter
Thanks for the info
jamessr23 likes this.
93sn8k is offline
post #7 of 16 Old 05-06-2019, 01:19 PM
A1 cardone part#842884MA comes with tfi module and steel gear
1989stang818 is offline
post #8 of 16 Old 05-09-2019, 06:59 AM
steel1's Avatar
Trader Feedback: (59)
I've been running a Spectra FD19 on my 393w, it comes with a steel gear, all the guts/tfi/shutter wheel have been swapped for Motorcraft components.
All the Motorcraft electronics can be found on rock auto except the shutter wheel , you can use the factory one off a 302 distributor or get the one from Pro M.
I've had issues with the aftermarket shutters.
steel1 is online now
post #9 of 16 Old 05-13-2019, 12:41 AM Thread Starter
Put a new 351w "AUTOZONE" distrib in and it didnt want to drop all the way down without binding up...
Went in all the way down to about the last 1/4 inch , had to use the distrib bolt to tighten it down into place, not wanting to do that...
Obviously car wont turn over very good like that...actually car would not start on that distrib anyway...(i know risky) but desperate to get it to fire and eliminate the hard to start issue...
So i put old motorcraft distrib back in to avoid tearing up anything..
Old motorcraft distrib drops right in flush
Everytime we try to find the right distrib at parts house its always wrong
What is the correct part number for the replacement distrib ??
Autozone ?
Advance auto ?
Pepboys ?
Oreily ?
93sn8k is offline
post #10 of 16 Old 05-13-2019, 07:09 AM
steel1's Avatar
Like I posted above use a Spectra FD19 I believe I got mine at Autozone. Not sure what year your 351w block is but on my 69 block
I had to trim about 1/4" off dist. shaft for shorter deck height.
In my experience running an aftermarket distributor without changing the electronics to Motorcraft is going to cause issues.
post #11 of 16 Old 05-13-2019, 10:49 AM
Autozone ?
Advance auto ?
Pepboys ?
Oreily ?
Funny, you bash MSD in your first post, but I bet you wouldn’t have any problems if you put a nice MSD unit in there. Never had an issue with mine. Actually several of them.
post #12 of 16 Old 05-14-2019, 07:36 PM Thread Starter
MSD DISTRIB .......
i spent my money on a new one for 302 yesrs ago !!
It failed with less than 100 miles on it
Had a dead miss in it....
Put stock ford distrib in it on ANDERSSON FORD DYNO
PROBLEM fixed !!!!!
(after replacing every other part that could fix a miss ) plugs cap rotor wires etc...while on dyno
I am not spending $300. On a distrib
When i can factory replace one for $100.
93sn8k is offline
post #13 of 16 Old 05-14-2019, 07:47 PM
Do your thing man. Doesn’t seem like you’re having much luck though
post #14 of 16 Old 05-21-2019, 01:18 AM Thread Starter
I ended up with a MSD 351w distrib for my motor.....
A friend had one on the shelf
Hopefully it works this time around
93sn8k is offline
post #15 of 16 Old 05-21-2019, 08:14 AM
ZEN357's Avatar
I used to run MSD but have heard really bad things about their quality now and am looking for another brand for my next build.
ZEN357 is offline
post #16 of 16 Old 05-21-2019, 10:03 AM
Well my friend, I hope this one serves you well and doesn’t give you any problems.
Blown motor, what to do now? jarryd2018 GT & SOHC 15 04-29-2010 11:09 PM
whats needed to run a 351w in a fox body crazygn 5.0/5.8 Engine Tech 13 10-21-2006 06:10 PM
351w EFI and swap parts for FOX body, Detroit area only please, no shipping at all. Boosted Windsor Engine Parts 5 03-04-2005 03:05 AM
351w EFI and swap parts for FOX, Detroit Area ONLY Boosted Windsor Engine Parts 4 02-14-2005 09:01 AM
