5.0 head selection question - Ford Mustang Forums : Corral.net Mustang Forum
 78Likes
post #1 of 74 Old 04-20-2019, 01:15 PM Thread Starter
Debogotthis69's Avatar
Ok Im building my 302 the block at the machine shop now going 30 over with forged flat top dss racing pistons also decking block this car will be na and street driven probably Saturday and Sunday car lol will be going with long tube headers mega squirt and more then likely edelbrock rpm2 intake. So Ive been looking at pro comp 180cc heads I dont know anything about them and been looking at dart and edelbrock heads so I want to hear the good the bad and the ugly lol afr heads are out the budget and trick flow Im iffy about will run lunati cam believe life is 549/565
Debogotthis69 is offline
post #2 of 74 Old 04-20-2019, 06:21 PM
What’s your actual budget?
1996 Mustang
347, 205 11R's, Box R Intake, Ported lower, custom comp cam, 42lb injectors, 255LPH, pro-m 80, 75mm Cheap-ass TB, 1 3/4 x 3in LT's, exhaust by me, A5 trans, 4.10
422WHP/456Ft/lb. Tuned using QH by Tony @ Tuners Inc.
96pushrod is offline
post #3 of 74 Old 04-20-2019, 06:39 PM Thread Starter
Budget is iffy lol Im buying piece by piece really and seen promaxx 180cc r 980 for the pair
post #4 of 74 Old 04-20-2019, 07:34 PM
JV106's Avatar
Keep saving and get some 190 11r’s.
Nitrous Al and 7mmremmag like this.
JV106 is offline
post #5 of 74 Old 04-20-2019, 07:48 PM
Nitrous Al's Avatar
Stop the machine shop ASAP. If you're building an engine, just start with a 351w.
'88 5.0 GT hatch AOD 3.08
stock 302, Ed Curtis cam & 11R 190 heads,
Holley SM2, 320 hp 332 tq to the wheels
Nitrous Al is offline
post #6 of 74 Old 04-21-2019, 08:46 AM Thread Starter
Well as of right now don’t got the cash to do the 351w
post #7 of 74 Old 04-21-2019, 10:29 AM
punc∑tu∑a∑tion
noun
The marks, such as period, comma, and parentheses, used in writing to separate sentences and their elements and to clarify meaning.
Learn it. Embrace it. Use it. Be understood.
Saleen414 likes this.
tjm73 is offline
post #8 of 74 Old 04-21-2019, 04:09 PM
Mark O'Neal's Avatar
To answer your actual question...I'm assuming this is a budget build and you're limited on how may pennies you have to waste on it. So....I'd avoid the ProComp unless you have a friend that is a machinist that likes to work for free. The ProMAXX are a much better quality part for the money.
The Trick Flow, in whatever flavor you prefer, won't do a single thing any other head would do in this application, and all the OTS pistons are made for 20 degree heads, so why create uncertainty for bragging rights?
You've got a decent plan. Follow your plan.
Mark O'Neal is offline
post #9 of 74 Old 04-25-2019, 02:39 PM
If its just a Saturday, Sunday car then just do a search for "Big Dogs Porting", (check facebook), tell him what you are looking for and he will hook you up. Better performance and under your budget. I've had eight mustangs with all sorts of combos, AFR, Trick Flow, FMS, etc. My aggressively ported GT-40 mild build stuff runs way better on the street then all the others I've had. Better quality parts, attention to detail and matched combination are the trick.
GreyGhost86 and JFraser27 like this.
LEE Boss is offline
post #10 of 74 Old 04-27-2019, 07:26 PM
AFR165's work REALLY well on mild 5.0's. May be out of budget, but check the classifieds....sometimes they'll pop up on the used market for what a set of chincanese heads go for new.
Also don't discount the Edelbrock Performer RPM heads....I picked up a set last Friday, used, for $400 WITH a nice set of Comp stainless rockers. Guy was upgrading to a set of cleveland style heads and dumped the edelbrock's because apparently nobody uses them anymore. That said, I've personally taken my Maverick into the 9's with the exact same heads (N/A)-- so they can work just fine.
'92GT, 427" and '93 "LXVO" coupe
toddturbo is offline
post #11 of 74 Old 04-27-2019, 10:09 PM
Originally Posted by toddturbo View Post
chincanese
Calling them Chinese heads is one thing, but that ^^^^ is just straight racist.
tjm73 is offline
post #12 of 74 Old 04-27-2019, 10:12 PM
Ryno22980's Avatar
I don't think great deals on used AFRs or TFS heads show up on the classifieds very often anymore. I've been watching for months. People want $1300+ for decent but used of the mentioned heads and most would still need to be checked out at a machine shop.
Hard to justify spending that on used when you could use a coupon code and get TFS170s for about the same from LMR. However, if you don't buy new heads from an engine builder for $1600-1700, you might end up with a machine shop bill anyway.
Ryan O.
'89 GT Vert
Ryno22980 is offline
post #13 of 74 Old 04-28-2019, 12:38 AM
When the H-Beam rods were forst imported we all called them "Commie Carrillos." But...that was in the 80s, before political racism was invented.
Ed Curtis and JFraser27 like this.
post #14 of 74 Old 04-28-2019, 06:51 AM
Stangdawg's Avatar
Mark, today there are many international marriages.
My Wife is a Singaporean. A highly educated one at that. Calling someone a chinc is racist.
It’s not based on your perception but the perception of the person on the receiving end. It’s not at all political to not denigrate other people it’s simply a matter of respect.
1989 GT - 347 build in progress
Stangdawg is offline
post #15 of 74 Old 04-28-2019, 07:04 AM
Saleen414's Avatar
Itís not based on your perception but the perception of the person on the receiving end. Itís not at all political to not denigrate other people itís simply a matter of respect.
Exactly what person "on the receiving end" was "offended" by those comments? Oh, you can not name any specific person? Then it did not happen. Lighten up buttercup.
26 X 8.5 Hoosier
Saleen414 is offline
post #16 of 74 Old 04-28-2019, 07:16 AM
Stangdawg's Avatar
Someone above specifically called the post out as racist.
There is no lighten up about it. I can’t help if you are culturally ignorant. But I can tell you that calling something chincanese is flat out racist.
Common things that racists do:
1. Deny it exists
2. Call those who complain too sensitive.
3. hate being called out
post #17 of 74 Old 04-28-2019, 07:24 AM
Saleen414's Avatar
You need to quit being offended for other people and worry about yourself. Anybody can call me whatever they want and I am not offended. I choose to not be offended. You choose to be offended for someone else...stop it. You are part of the problem.
Ed Curtis, tmoss, KEVIN$ and 8 others like this.
26 X 8.5 Hoosier
post #18 of 74 Old 04-28-2019, 09:03 AM
Stangdawg's Avatar
I didn’t chose to be offended WHITE BOY, someone posted a racist post. It’s offensive. I’m not the only one who called it out.
Maybe you should get a dose of racism thrown at you. Go overseas and talk #### and when you get your teeth knocked out then it will ring true.
You live in white ass Maine. You lack any cultural awareness.
When you’ve experienced racism first hand then you’ll get it. Until then STFU.
Being silent about it doesn’t fly with me MFer.
Until then STFU.
post #19 of 74 Old 04-28-2019, 09:08 AM
Old timer
Ed Curtis's Avatar
WTF?
Quote Mark O'Neal:
"Virtually every customer I have has the same first interest. That is what is the lowest price he can pay. People like myself, Ed and very few others on this board have spent decades learning what we know.....and y'all want that knowledge for free....and you'll take the parts for free as well."
Ed Curtis is offline
post #20 of 74 Old 04-28-2019, 09:56 AM
Couldn't help but notice post #18.
2 step is online now
post #21 of 74 Old 04-28-2019, 11:34 AM
I can. Me. I found it and all racism patently offensive. It serves no purpose. Ignorant people are racist. I am not Chinese. That doesn't mean I can't call out someone being racist when I see one.
Even if you can't see that is racist, it doesn't mean that it isn't. Racism is racism. That post was racist. You can deny it all you want, but it was as racist. End of debate.
tjm73 is offline
post #22 of 74 Old 04-28-2019, 11:40 AM
Calling out racism is not being part of a problem. Sitting idly by is being part of the problem.
tjm73 is offline
post #23 of 74 Old 04-28-2019, 12:27 PM
AtomicCoupe's Avatar
Pathetic if you ask me
Stock block 306, V1 T-trim, AFM B-451 cam, TFS Twisted Wedge, Holley Systemax, A1000, Snow Meth, TKO 600, Team Z, Strange, MM, Lakewood and Moser helps me go forward fast.
AtomicCoupe is offline
post #24 of 74 Old 04-28-2019, 01:29 PM
Saleen414's Avatar
It was racist to you. Not to me. I refuse to let others define me or my freedom of speech and thought. People who want racism tend to find racism. Just like that Jussie Smullet character. He needed racism to validate his own misguided feelings, he could not find it, so he invented it to justify his "feelings". So much is made of so little. When I was growing up there was this little rhyme "Sticks and stone may break my bones, but names will never hurt me". You are looking to be offended at something not directed at you. Congrats, you found it. You also are part of the problem for taking something personal that had no bearing on you other than your "feelings". Like I said previously: lighten up buttercup. Life is too short to have angst over every spoken or written word, whether real or perceived.
tmoss and 91GTstroked like this.
26 X 8.5 Hoosier
post #25 of 74 Old 04-28-2019, 01:35 PM
Saleen414's Avatar
I didnít chose to be offended WHITE BOY, someone posted a racist post. Itís offensive. Iím not the only one who called it out.
When youíve experienced racism first hand then youíll get it. Until then STFU.
Being silent about it doesnít fly with me MFer.
Until then STFU.
Dude, you know nothing about me. I have lived most of my 58 year life in the Seattle area. I moved to Maine a year ago. I know real racism, not your made up BS. Real racism is almost non existent. You are another person that needs racism to validate your feelings. Your life sucks. I refuse to let you or anyone else tell me how to think or feel. If you don't like it, that is your problem, not mine. Do not call me a racist, because you can find no evidence of it.
26 X 8.5 Hoosier
post #26 of 74 Old 04-28-2019, 02:09 PM
Until then STFU.
He also started off with a racist “white boy” comment and said you were from “white Maine”....he’s from “white” NH. So he’s calling you out for racist comments using other racist comments. WTF? But he’s such a worldly tough guy. Prob never left Nashua or whatever thug neighborhood he lives in.....in NH.
Anyways, this country needs to unite as AMERICANS and care for each other as AMERICANS. You can be proud of your culture and ancestry, hell ya, but remember we’re all AMERICANS. We aren’t the same race and that’s ok, but we are all AMERICANS.
Ed Curtis, Saleen414 and luv2rock like this.
post #27 of 74 Old 04-28-2019, 02:19 PM
You can justify to yourself about remaining ignorant about racism all you want. Racism is still racism. Calling someone or something "chinc" is racist. It is racist just the same as any other racist name. Racist is racist even if the target doesn't hear it.
You also assume I am taking something personally when I am not. I can't take something personal when it's not directed at me. But I can see that it's racist and call it out. Which I did. You are actively arguing the indefensible position of deliberately remaining ignorant about that in fact being a racist term. You are actually arguing to be racist. It is your right. Own it. Enjoy it.
tjm73 is offline
post #28 of 74 Old 04-28-2019, 02:58 PM
Saleen414's Avatar
I am just explaining to you that you will find racism if you want to find it, whether it is racism or not. You have a very broad all encompassing definition of racism. I believe it is much more narrowly defined. You can not impose your own definition on all people, just because you believe it to be true. I believe in free speech and free thought. You seem to believe in thought control and curtailing freedom of speech. You can define me however you want, thing is, I do not put an ounce of thought into what you think of me. You have the problem, not me. Keep banging that drum if it makes you happy, I do not care.
Ed Curtis, tmoss and Mark O'Neal like this.
26 X 8.5 Hoosier
post #29 of 74 Old 04-28-2019, 03:00 PM
Old timer
Ed Curtis's Avatar
tmoss, Saleen414, petmotel and 1 others like this.
Quote Mark O'Neal:
post #30 of 74 Old 04-28-2019, 03:15 PM
Wow, did this thread go sideways or what? What the heck is the topic supposed to be?
Dono2 likes this.
petmotel is online now
post #31 of 74 Old 04-28-2019, 03:51 PM
Saleen414's Avatar
Some people think it is a racist topic.
26 X 8.5 Hoosier
post #32 of 74 Old 04-28-2019, 03:55 PM
Yeah....I don't much care what other people think, being a victim is political power.
As for racism, everyone in America has a right to be as racist as they want to. They have a right to say what they want to. I'm not going to get wound up about it one way or the other. I don't really care about people's "perceptions." If you want to run around pleasing everyone, go ahead. You'll wind up pleasing no one, not even yourself.
Ed Curtis, tmoss and Saleen414 like this.
post #33 of 74 Old 04-28-2019, 03:58 PM
There is no lighten up about it. I canít help if you are culturally ignorant. But I can tell you that calling something chincanese is flat out racist.
1. Deny it exists
I said "Commie Carrillo."
The rods were from China. China is a Communist nation.
Get a grip.
Ed Curtis and tmoss like this.
post #34 of 74 Old 04-28-2019, 03:59 PM
Until then STFU.
There is an "X" in the upper right hand corner.
post #35 of 74 Old 04-28-2019, 04:01 PM
No. The problem is people that can't mind their own business.
Ed Curtis and Saleen414 like this.
Car Rarity? preppypyro General Mustang Tech 8 04-13-2016 01:14 PM
'89 5.0 H.O. Head bolt question rh1231979 General Mustang Tech 2 03-22-2009 08:09 AM
This may help some of you with PI Headswap questions. Modular GT & SOHC 0 01-24-2009 04:32 PM
5.0 Parting out, many stock and performance parts 91stang31 Windsor Engine Parts 0 12-21-2008 07:39 PM
5.0 head help 65juicestang 5.0/5.8 Engine Tech 2 08-29-2008 07:21 PM
