Built 8.8 or team z 9 inch - Ford Mustang Forums : Corral.net Mustang Forum
 2Likes
  • 2 Post By Ed Curtis
post #1 of 9 Old 04-07-2019, 06:51 PM Thread Starter
I'll be hovering around 1000 hp on my foxbody .should I build up my 8.8 or go with the team z 9 inch which I can get for about half the price of retail..thanks
Darrenstang is offline
post #2 of 9 Old 04-07-2019, 08:29 PM
An 8.8 can be set up to handle some pretty serious power. Imo once you get to 4 digit power it’s not a bad time to consider a 9in. For you, being able to get it half price should make that decision easy.
1996 Mustang
347, 205 11R's, Box R Intake, Ported lower, custom comp cam, 42lb injectors, 255LPH, pro-m 80, 75mm Cheap-ass TB, 1 3/4 x 3in LT's, exhaust by me, A5 trans, 4.10
422WHP/456Ft/lb. Tuned using QH by Tony @ Tuners Inc.
96pushrod is offline
post #3 of 9 Old 04-07-2019, 09:18 PM
Trader Feedback: (41)
9 inch
stangjumper is offline
post #4 of 9 Old 04-08-2019, 07:50 AM
Saleen414's Avatar
An 8.8 takes less HP to turn. Built correctly they can handle well over 1K power. If it is a stick shift car then the 9" is probably a better option because it can take higher shock loads than a 8.8. The 9" is nice because it is easier to change out a gear set. The 9" is heavier (weight) than the 8.8. The 8.8 can only go up to a 35 spine axle, while the 9" can go to a 40 spline axle no problem. I run a 8.8 and the engine makes about 1,250 hp. I am still using 1/2" wheel studs with no issues, although most people in this power range and above go to a 5/8" wheel stud.
26 X 8.5 Hoosier
Saleen414 is offline
post #5 of 9 Old 04-08-2019, 10:38 AM
The Team Z outlaw 9 is in my car, and it is a thing of beauty! You won't regret it.
FastDriver is offline
post #6 of 9 Old 04-10-2019, 10:28 AM
Old timer
Ed Curtis's Avatar
Originally Posted by Saleen414 View Post
An 8.8 takes less HP to turn. <snip>
Actually, when you take into consideration housing deflection under load, the nine is better.
FastDriver and Mike Moore like this.
Quote Mark O'Neal:
"Virtually every customer I have has the same first interest. That is what is the lowest price he can pay. People like myself, Ed and very few others on this board have spent decades learning what we know.....and y'all want that knowledge for free....and you'll take the parts for free as well."
Ed Curtis is offline
post #7 of 9 Old 04-10-2019, 11:24 AM
Saleen414's Avatar
Depends on the load.
26 X 8.5 Hoosier
post #8 of 9 Old 04-10-2019, 11:34 AM
I think the OP specified that. 'preciate the info, Ed. Didn't know that.
post #9 of 9 Old 04-10-2019, 12:58 PM Thread Starter
Thanks for everyone's input.
Want To Trade built 8.8 set-up for IRS eleanorfox Suspension 0 04-09-2012 10:25 AM
For Sale Team Z built 8.8 with Aerospace Brakes all NEW aplusdetailshop Drivetrain Parts 8 02-29-2012 04:01 PM
For Sale 92 roller part out procharger built trans built 8.8 seeuinmyrearview Miscellaneous Mustang Parts 3 11-06-2011 03:21 PM
For Sale Built 8.8 narrowed/35 spline strange TAT2MAN Drivetrain Parts 1 02-12-2011 10:23 AM
Built 8.8 with aluminum driveshaft, brakes, all suspension!!!! svtcobra2k1 Drivetrain Parts 4 11-24-2006 01:40 PM
