What mini starter to buy and why - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By 1995gtCPE
post #1 of 25 Old 04-01-2019, 08:41 AM Thread Starter
dgrobels's Avatar
recently bought one off LMR the SVE branded starter
it wasn't the best, dint engage properly and ended up dying after about 10 starts
I HAVE A 10:6:1 427W and need a new starter
any recommendations?
dgrobels is offline
post #2 of 25 Old 04-01-2019, 09:29 AM
Mustang5L5's Avatar
I run the PA performance starter on mine. No complaints at all although i'm turning over a stockish 302. Love how it sounds on startup though
Mike
--1988 Mustang LX 5.0--
Mustang5L5 is offline
post #3 of 25 Old 04-01-2019, 09:53 AM
Please call me Mike
mr_minnis's Avatar
Trader Feedback: (46)
Have you thought about using one of the later model ones for like a 93? It’s not a true mini starter but it is smaller than a traditional and less expensive.
84K 88 LX Vert 5spd: 3.73s.
mr_minnis is offline
post #4 of 25 Old 04-01-2019, 10:42 AM
https://www.summitracing.com/parts/s.../model/mustang
I've had good luck with this Summit branded starter on an 11:1 363 with headers and road racing pan. Clocking is a must for my app, at least for a geared starter.
Jay
petmotel is offline
post #5 of 25 Old 04-01-2019, 06:03 PM
midnightlaundry's Avatar
I only ever had one, and it's still in the car 17 years later..
https://www.summitracing.com/parts/p.../model/mustang
midnightlaundry is offline
post #6 of 25 Old 04-01-2019, 06:34 PM Thread Starter
dgrobels's Avatar
Bought a 94gt starter hopefully it'll work and last long
dgrobels is offline
post #7 of 25 Old 04-01-2019, 06:51 PM
1995gtCPE's Avatar
Trader Feedback: (34)
Powermaster Ultra Torque here. Won't have anything else now.
TaraFirma likes this.
1995gtCPE is offline
post #8 of 25 Old 04-01-2019, 07:11 PM
10.8:1 using a pa performance here. Works great whether it’s hot or cold.
1996 Mustang
347, 205 11R's, Box R Intake, Ported lower, custom comp cam, 42lb injectors, 255LPH, pro-m 80, 75mm Cheap-ass TB, 1 3/4 x 3in LT's, exhaust by me, A5 trans, 4.10
422WHP/456Ft/lb. Tuned using QH by Tony @ Tuners Inc.
96pushrod is online now
post #9 of 25 Old 04-01-2019, 08:30 PM
Stangdawg's Avatar
I’ve also got the PA performance mini starter and had it for 6-7 years with zero issues.
Currently have a 11.3:1 347 and so far no issues turning it over
1989 GT - 347 build in progress
Stangdawg is offline
post #10 of 25 Old 04-02-2019, 12:06 AM
Had the very same PA performance starter on my race car about 12-13 years now, still works great.......
green valley is offline
post #11 of 25 Old 04-06-2019, 02:06 AM
Short Circuit's Avatar
Trader Feedback: (74)
I use https://mean-green.com/
You just gotta pick up the phone and call them. They have our application.
93, 95, 96, 08
06 Ducati S2R 1000 (Totaled)
06 Ducati 749S
12 Triumph Thruxton 900
03 Porsche 996 Turbo (Totaled)
98 Porsche 993 (Soon)
Short Circuit is offline
post #12 of 25 Old 04-06-2019, 08:37 PM
I have a 11-1 dart block 427,with lots of initial timing. I used the original stock starter, (93) that
worked fine,for 3 years with the 427. It just died a few months ago. I bought a new stock style
starter at the auto parts store and it works fine. I do have 2 rear mounted batteries.
427 T56 3.73 2 kits
JB Books is offline
post #13 of 25 Old 04-09-2019, 07:34 AM
ZEN357's Avatar
Here are some options for you to look at, not sure what your budget is...
https://www.jegs.com/webapp/wcs/stor...rsistYmm=false
ZEN357 is offline
post #14 of 25 Old 04-09-2019, 10:55 AM
powermaster has my vote
b--rad is offline
post #15 of 25 Old 04-09-2019, 11:04 AM
If that's your car in your avatar, it should already have a mini-starter and if it needs to be replaced, you should try to find a local shop that rebuilds starters. The OEM mini-starter should do that job without issue. And it should be cheaper than buying a new, sometimes questionable quality, unit.
tjm73 is offline
post #16 of 25 Old 04-09-2019, 11:25 AM
Ssp 363's Avatar
I bought the powermaster for my 92 mustang with ford racing boss block 427.
I have not installed it yet but it looks like a real nice piece.
Stock style auto parts store starter will only start car at first start up. Once driven and engine warms up it gets heat soaked and car has to cool down for it to restart.
92 ssp mustang coupe
Ford racing boss 427 540hp 555tq 1/4 mile 11.07 @127
AFR205cc heads w/58cc chambers
Trickflow R intake with box upper/90mm throttle body
Ssp 363 is offline
post #17 of 25 Old 04-09-2019, 12:05 PM
The stock starter will turn that engine over hot or cold. If it won't fire when hot, that's not a starter issue. If it is sluggish to turn over, it's a heat control issue and the starter probably needs a heat sheild to protect it from the header heat and/or the wiring to the starter is not sufficient and/or your battery is not up to snuff.
tjm73 is offline
post #18 of 25 Old 04-09-2019, 01:52 PM
Similar situation here....438" windsor, 15:1, methanol. Stock PMGR starter cranks fine. HOWEVER, with the battery in the back of the car, it has a appreciable voltage drop between batt and starter which I haven't addressed yet. That could be the relay or a wire issue or whatever. It is currently running with a 16v battery (no alternator, not needed in my case but they do make them in 16 volt) and at 16v, it cranks over like the spark plugs are out. But I also think that I've band-aided it with more voltage. 12v used to work fine.
DB electrical has a few starters too....I ain't never had any problems out of them. Some have. I keep a spare "just in case". Cheap enough to keep one. Have one on my little 2.3 and it cranks 10x faster than the factory starter ever did-and it was rebuilt. Probably a winding issue with the original as the brushes and solenoid were new/great shape. I just got tired of fiddling with it and bought a DB starter. Dad has one on his 7.3 Powerstroke which has been in service for, gosh, 12 years or so? And has one on his Maverick and his Mustang.
toddturbo is offline
post #19 of 25 Old 04-09-2019, 03:27 PM
I had a battery in the back of the hatch hot start issue. I moved the battery back to the engine bay and corrected some wrong size wiring and the problem went away.
tjm73 is offline
post #20 of 25 Old 04-09-2019, 04:16 PM
Not so,my car whips over hot/cold or any where in between.
427 T56 3.73 2 kits
JB Books is offline
post #21 of 25 Old Yesterday, 10:34 AM
TaraFirma's Avatar
Another vote for Powermaster. Bought one in 2005 after dealing with starter issues over the years. Iíve NEVER had a problem with it. Worth every penny to not have to dick around with starters for the last 14 years.
To fly is Heavenly, to hover is divine.
Don't let your mouth write a check your a$$ can't cash.
TaraFirma is offline
post #22 of 25 Old Yesterday, 01:32 PM
Ssp 363's Avatar
Yeah i think its a heat control issue too getting to hot from the headers i bought a starter heat wrap shield made from some type of lava rock material from summit to go on it.i may just wrap the stock starter with it first and see how it does. I have a 4 guage cable from starter to solinoid on fender.battery is in the trunk ....
Ssp 363 is offline
post #23 of 25 Old Yesterday, 02:21 PM
What gauge is the wire to/from the trunk? You should have at minimum 1/0.
tjm73 is offline
post #24 of 25 Old Yesterday, 05:55 PM
Ssp 363's Avatar
It is 1/0 guage copper
Ssp 363 is offline
post #25 of 25 Old Yesterday, 08:55 PM
I saw a heat shield product that was a piece of aluminum with an applied material that was good for 1800 degrees on one side and less than 1/4" clearance on the other.
tjm73 is offline
