Can you run 10's with a 347? - Ford Mustang Forums : Corral.net Mustang Forum
 20Likes
post #1 of 69 Old 07-01-2018, 12:21 AM Thread Starter
Alexender's Avatar
347 10:5:1
TFS 11R 190cc
Custom HR camshaft
Victor JR intake
750 Holley DP Carb
1 3/4 LT headers
3 inch off road X-pipe
3 Inch Catback
Astro T-5
93 Octane
3.73 Gear
Car
93 Coupe
Fiberglass hood
Full tubular k-member
Drag radials
Back seat Delete
No A/C
Even 10.99?
Alexender is offline
post #2 of 69 Old 07-01-2018, 12:46 AM
rob
rob's Avatar
Trader Feedback: (23)
Yes it could if you can drive. I would want a 4.10
rob is offline
post #3 of 69 Old 07-01-2018, 01:13 AM
Unfortunately not. 11s if you're lucky. Most likely low 12s.
bluemp301 is offline
post #4 of 69 Old 07-01-2018, 01:15 AM Thread Starter
Alexender's Avatar
People run low 12s with 302s.
Basic TFS top end combo run 12.23, 12.30 110mph with 302 300rwhp ...
post #5 of 69 Old 07-01-2018, 02:09 AM
rob
rob's Avatar
For most of us, it would be harder with a manual transmission.
We put together a 363 with base 66cc 11r 190 heads for 10:1 compression. With a c4, ed hr cam, otb air gap, 4.10, etc..
It went 7.12 with the old carb and good weather which calculates to 11.1.
Friday in horrendous weather and a new apd carb it went [email protected] when most were a tenth and a half slower. [email protected] converts to [email protected] A while back he went 11.4 in the 1/4.
This is a pump gas, street driven and raced by a 70 year old man.
The parts listed can do what he wants.
rob is offline
post #6 of 69 Old 07-01-2018, 02:10 AM
rob
rob's Avatar
Above with 28 inch tall drag radial. Ill find out the rest of the slip.
rob is offline
post #7 of 69 Old 07-01-2018, 06:28 AM
fox88's Avatar
There are guys out there that have done it, with stock bottom ends in lightened cars, so why not? Will be harder to do it in a stick vs. an auto though. If that were me, I'd do the 205 11r's, solid roller and c4. Just sounds fun! lol
What's his face on here (who just happens to be local to me) runs in the 9's with an NA 363. Surely you could follow his build with your 347.
FTI TW heads/FTI cam/RPMII/A-trim/T5 & 4.10's/QH w/ BE & EA/GUFB
www.carstereooneinc.com
fox88 is offline
post #8 of 69 Old 07-01-2018, 09:02 AM
I couldn't resist a good troll. This shouldn't even be a question. As mentioned people have done this with stock bottom ends. One went 10.69 at almost 128mph with 11r 190s and a 100k mile shortblock. Google is your friend.
post #9 of 69 Old 07-01-2018, 10:54 AM
Quarterhorse ll runs 9.80s with a NA 331, 5 speed.
69.5 Maverick, 480 RWHP 363 NA, Faceplated TKO 600, 4.30 gears, 9", E70-14 Whitewalls. "Stock Appearing" Sleeper. 1.72, 11.49 @ 124.87
tbirdz12 is offline
post #10 of 69 Old 07-01-2018, 07:04 PM
GilroyRacing's Avatar
Trader Feedback: (111)
I've been 10.60s
91 Fox
R.I.P. 347: 1.43 60' [email protected] 1/8th [email protected] 1/4
302 1.59 60' [email protected] [email protected]
GilroyRacing is offline
post #11 of 69 Old 07-01-2018, 09:21 PM
Dean Scheidt
SLO 5-OH's Avatar
Trader Feedback: (53)
Yes it can. My only suggestion for the track is Mickey Thompson 26x10 stiff-wall ET Drags. Other than that, your combination looks good as long as you can shift that 5-speed. Check out post # 882 on the last page of my 347 thread.
https://forums.corral.net/forums/5-0-...ly-better.html
The key is having a plan and using the right combination of parts.
1989 Mustang GT - original owner
1/8-mile: 6.57 @ 102.67
1/4-mile: 10.40 @ 128.13 (1.37 60')
425 RWHP:
, TW 205 heads, tmoss TFS Box-R intake,
AOD,
8" converter, 4.10's, Team Z Suspension, M/T 26" ET's, full interior, 3,360 lbs race weight. Tuned by Willie at
SLO 5-OH is offline
post #12 of 69 Old 07-01-2018, 09:23 PM
Dean Scheidt
SLO 5-OH's Avatar
Originally Posted by GilroyRacing View Post
I've been 10.60s
You need to post a picture of your wheels up launch.
425 RWHP:
AOD,
SLO 5-OH is offline
post #13 of 69 Old 07-02-2018, 12:04 PM
How can you say that without knowing where his engine makes peak power and what tire size?
FastDriver likes this.
CHP/CPR (Coast High Performance) / (Custom Performance Racing Engines)347 lasted a whopping 500 miles due to poor machining, metal debris in main bearings, damaged cam bearing and a balance job that was off 64ozs!
Buyer Beware.
fasterthangas is offline
post #14 of 69 Old 07-02-2018, 12:58 PM
Exactly my thoughts when I read that.
FastDriver is offline
post #15 of 69 Old 07-02-2018, 01:40 PM
rob
rob's Avatar
I made too many assumptions based on what I would do to crack into the 10s. Not 11 or 12s.
6500-6600 shift point and a 26 tall tire with low to mid 120 traps.
My 363 is lower compression with a ported victor jr, Ed cam with 6500 shift point, 4.10 and 26. So if he does everything I assumed he will be good to go
rob is offline
post #16 of 69 Old 07-02-2018, 02:49 PM
I made too many assumptions based on what I would do to crack into the 10’s. Not 11 or 12’s.
6500-6600 shift point and a 26” tall tire with low to mid 120 traps.
My 363 is lower compression with a ported victor jr, Ed cam with 6500 shift point, 4.10 and 26”. So if he does everything I assumed he will be good to go[IMG class=inlineimg]/forums/images/smilies/wink.gif[/IMG]
Well someone had to raz you. 😁
Buyer Beware.
post #17 of 69 Old 07-02-2018, 03:38 PM
blackout50's Avatar
Like this? https://m.youtube.com/watch?v=6gQbAxW1SCc
no one knows. thats the issue with EFI, too much guessing.
wisdom from bolt-on-bandito
blackout50 is online now
post #18 of 69 Old 07-02-2018, 04:19 PM
You can run a lot faster than 10's if you spend a lot of money and plan on 5 digit RPM. Look at Comp Eliminator.
zenboy99 and wytwolf like this.
toddturbo is offline
post #19 of 69 Old 07-02-2018, 04:31 PM
Holy crap!!!
tony91723 and Racer R like this.
Buyer Beware.
post #20 of 69 Old 07-03-2018, 12:16 AM
cab0154's Avatar
4.040 stock 1971 302 block, scat rotator with 9000 crank, studded mains, some srp pistons with a little dome that we actually ground down a little to clear the valves, 11.5:1 compression, .660 lift old comp solid roller, some RHS 215s with a little work (308 cfm), ported vic jr, holley 830 annular, 5500 rpm converter, c4, 4.30s and some 3053s. [email protected] in the 1/8th off the foot brake on motor in an LX hatch at 2900lbs. 7200 shift point. that little turd hauled ass for what it was. so 10s are most definitely possible.
cab0154 is offline
post #21 of 69 Old 07-03-2018, 08:04 AM
I had a 93 gt I built a 347 for. i had procomp 210 cc heads, trick flo stage 2 cam, electric accessories, no power steering (pretty easy to steer without it), 11.4-1 compression, (ran fine on pump gas and great on race fuel), 750 dp, with a cheap intake cant remember the brand, 3:73 gears 1 3/4 long tubes, fiberglass hood and hatch, 5 speed, ran 11:80's added a 75 shot and after dialing it in good got it down to the best time of 11.60's full interior street car on drag radials with bone stock suspension.
Sent from my SM-G950U using Tapatalk
nackewoodworks is offline
post #22 of 69 Old 07-03-2018, 10:16 AM
EscortSportage's Avatar
I believe you can run 10s with a 302. But 90+% of people arent willing to do what it takes to get there.
Get the car down to 2000lbs and with lots of aero work, HP is the easy part, then use a powerglide trans...(im no drag racer)
instagram.com/escortsportage
2480LBS
306W
EscortSportage is offline
post #23 of 69 Old 07-03-2018, 10:22 AM
Old timer
Ed Curtis's Avatar
Really? 2000 pounds? Not possible....
Over 20 years ago, a street based, pump gas 347 combination I worked on went 10.70s all day long. Old series Twisted Wedge heads, Victor Jr. intake, Holley 750DP coupled with a C4, ATI converter and 4.30 gears. (in a 3300 pound hatch)
Imagine what can be done today!
Quote Mark O'Neal: "Virtually every customer I have has the same first interest. That is what is the lowest price he can pay. People like myself, Ed and very few others on this board have spent decades learning what we know.....and y'all want that knowledge for free....and you'll take the parts for free as well."
Nil Satis Nisi Optimum
Ed Curtis is offline
post #24 of 69 Old 07-03-2018, 01:08 PM
ok just to be clear we are talking about a foxbody right?
I own an 89 GT shes high 25xx lbs and this is a real race car (trackcar) not that drag race skinnie fronts, tiny light weight k member and aerospace hollow brakes. Plus i still have stock windshield, quarter windows, stock fuel tank, iron block, stock rearend.
So which fox would i buy to break records?
1979 (ugly AF) but the lightest fox ever made
then we remove side mirrors, convert the car to a front feeder cooling setup, massive amounts of aero work to reduce drag, flat bottom, belly pans the works.
I am almost willing to bet we (corral knowledge and people) could get a 79 fox to 2200lbs sort of easy
2000lbs we would need carbon fiber and deeper wallets.
2000lb 79 fox
with someones 450hp 302 (im guessing carbed since we dont need reliability, drive-ability, we dont need power steering, #### we dont even need an alternator, ive seen drag race guys run off a battery for 1/4 mile then roll into the paddock. Electric water pump, have that 302 spinning!
2000lbs 450hp, aero, and throw in a good drag race driver, come on, we would be putting big blocks to shame!
2480LBS
306W
post #25 of 69 Old 07-03-2018, 01:20 PM
Old timer
Ed Curtis's Avatar
Again - a 2000 pound Fox body is not possible.
Throw all the carbonfiber and titanium at it you want but it'll never see a 2000 pound race weight.
You must be running radio controlled or X-box race cars to think that.
EvilGooses and thadude like this.
post #26 of 69 Old 07-03-2018, 01:28 PM
fox88's Avatar
More like 2lbs.
fox88 is offline
post #27 of 69 Old 07-03-2018, 01:41 PM
Last August at NJMP we rolled my car with me in it with my helmet, neck harness, gloves, and easily half a tank of gas.
2811 lbs
Ive removed more weight since then and cant wait to get it back on the scales,
youre telling me with a tubular front end (not just k member) and tubular rear end setup, 2gallon fuel cell, lexan, carbon, sticker headlights, sticker taillights, no dash with racepak we can get sub 2100 lbs
What is the record for the lightest fox? Is there any record for that?
2480LBS
306W
post #28 of 69 Old 07-03-2018, 01:45 PM
Ed
you just reminded me, i met a guy who dirt oval track races (yuck) a fox with a 4 banger, he told me it was 2300lbs IIRC and thats with a full oval track cage,
a 10 second drag car only needs what a 4 point? 6 point?
2480LBS
306W
post #29 of 69 Old 07-03-2018, 01:48 PM Thread Starter
Alexender's Avatar
all i know its that the 1979 notchback weight around 2,550 lbs.
That is the lightest fox ever made.
post #30 of 69 Old 07-03-2018, 01:53 PM
IF this is true, I can pull 500 lbs out on a Saturday. Welcome to the 9s boys! Gather around, ill learn you
2480LBS
306W
post #31 of 69 Old 07-03-2018, 04:22 PM
dstolarc's Avatar
I would love to see this :-)
Do you have 4 corner scales or a full car scale to show before and after weights?
This would be an awesome project we all could learn something from.
Please show us the results and what you removed to save 500 lbs.
dstolarc
willyt likes this.
______________________________________________
Those who say it can't be done should not interrupt those that are busy doing it.
dstolarc is online now
post #32 of 69 Old 07-03-2018, 04:29 PM
Old timer
Ed Curtis's Avatar
This is "dumb signature" worthy...
post #33 of 69 Old 07-03-2018, 05:59 PM
rob
rob's Avatar
dstolarc
Start with the easy things like removing fuel, coolant and air in the tires.
Out of curiousity, I wonder what has been the lowest race weight for a Fox?
rob is offline
post #34 of 69 Old 07-03-2018, 06:14 PM
I would love to see this 🙂
dstolarc
I wonder what the Grey Mare weighs? That thing was drilled like Swiss Cheese but had no cage or cooling system.
Buyer Beware.
post #35 of 69 Old 07-03-2018, 08:16 PM
You build your car the way it is for a few reasons.
1) You are building it to the rules to fit in a racing class.
2) You build it to get the most bang for your buck to achieve your performance goal.
3) You build it the way you want it not caring about cost or rules.
If you are building to class rules you have to spend lots of money to maximize what you are allowed. This can mean stock parts that end up costing more than top shelf aftermarket stuff but they are what you need to pass tech and be competitive. Take pure stock for instance. You can easily have over 10 grand in a "stock" engine.
If you want the most bang for your buck you can use the brute force approach. You don't need to have every detail perfect like a class racer because you can always add more cubes, or boost, or a bigger shot of nitrous, or better heads, etc.....
The more rare approach is to build what you want not caring about a racing class or cost. This is the "CleanLX" build. He wanted a really good running e7 head street combo and he paid the money for what he wanted.
I think the idea of trying to make a fox mustang light enough to run 9s with a stock short block falls into category #3. You might with enough money get a fox mustang to 2000 lbs without driver using enough carbon fiber, aluminum, and titanium. But this falls into the category of not a good return on your investment. There are much cheaper ways to run 9s. As an ex circle track racer I can remember looking in catalogs at hollow titanium bolt kits for sprint cars to save a few pounds at the price into the 5 figures.
If all you want to get into the 9s with 302 cubes naturally aspirated it is indeed possible and not even that hard if you are willing to spend the money. The reason it rarely gets done is that there are cheaper ways to go faster with more cubes, boost, nitrous, etc.
cleanLX likes this.
taco is offline
347 10s? Alexender 5.0/5.8 Engine Tech 7 10-07-2014 02:00 PM
will this run 10's ? AutoStang 5.0/5.8 Engine Tech 68 07-01-2014 02:45 PM
Will my 347 run without a tune? 94_cobRa 94/95 Tech 25 12-05-2013 01:52 AM
Fuel/Spark Ok will not run, Iginition switch problem Shottie 5.0/5.8 Engine Tech 12 07-05-2012 05:48 AM
For Sale 11:1 347 Pump Gas (Low 10's capable N/A) MustangN8S Windsor Engine Parts 5 03-27-2012 06:01 PM
