thoughts on broken roller rockers - Ford Mustang Forums : Corral.net Mustang Forum
 7Likes
post #1 of 46 Old 10-22-2017, 12:14 PM Thread Starter
Kingfish999's Avatar
so i apparently bought a set of knockoff Miller Mid-Lift rockers and 6 of them have the trunnions broken in half where the stud goes through. there only about a eyar only with only a few thousand miles on them. i went ahead and ordered a new set since its a daily driver but was wondering if i used these on a build that may get used only a a few times a year with a very mild cam if it would be alright.
Kingfish999 is offline
post #2 of 46 Old 10-22-2017, 12:29 PM
I'm certainly not an expert like several members here are, but here is my take on the situation:
-you mentioned knockoffs. You get what you pay for.
-you need to do some hard looking and make certain you don't have clearance issues that will continue to break rocker arms.
90MarkVII is offline
post #3 of 46 Old 10-22-2017, 12:44 PM
Saleen414's Avatar
How much did you pay for them? Now take that X2. Now how much have you paid for them? Amazes me that people can not (will not?) afford to do it right, but they can afford to do it over and over and over again....lol
26 X 8.5 Hoosier
Saleen414 is offline
post #4 of 46 Old 10-22-2017, 12:45 PM
I run real ones for a few years now with no issues. I put quite a few miles on the car every year often for long trips Although not a daily driver
turbo2256b is offline
post #5 of 46 Old 10-22-2017, 12:46 PM Thread Starter
i didnt know they were knockoffs till i emailed Miller last night and he pointed out that they are knockoffs that use cheap trunnions.
The trunnions in your rocker arms are NOT our trunnions. They've been replaced for a cheap offshore version by an "X" distributor of PVS rockers, and unfortunately, we have had to sell numerous buyers of these with the same product who thought they were getting a "deal" buying them for $225 or $275, or whatever. The trunnions in your rockers are SOLID (not gun-drilled); made from an inferior steel compared to the 8620 Bizmuth Aerospace steel we use; and lastly, don't have the double-flat on each side of the stud mounting hole which eliminates the sharp edge on the bottom of conventional trunnions. Even the few rocker manufacturers who "edge-break" that sharp bottom side of their stud hole, are not accomplishing the increased benefit of a full flat that has a "bevel" on the ID of the hole to be sure there's no chance of a stress-riser developing. The gun-drilled hole is NOT for lightening, it is for strength, just as with gun drilled axles. Having two surfaces to a diameter for case hardening heat treat is much stronger than one, where a solid trunnion will have a soft core that provides no strength, only weight.
post #6 of 46 Old 10-22-2017, 02:18 PM
Mark O'Neal's Avatar
A: I've broke cheap ones, I've broke expensive ones.
B: The world is 90% advertising and 10% asphalt.
tmoss likes this.
Mark O'Neal is offline
post #7 of 46 Old 10-22-2017, 09:13 PM
Enjoy_the_Ride's Avatar
So I bought a set from some guy named paul (I've seen him post around), he was selling them on ebay and said they were actual mid lift rockers miller lifters. when I got mine, one was missing a clip on the trunion. He sent me a new set. I never ended up using them and they are sitting on the shelf.
What does double flat mean on the trunion, flat on the nut side and flat on the head side?
I guess mine are fakes too? How do I find out?
Enjoy_the_Ride is offline
post #8 of 46 Old 10-22-2017, 10:27 PM Thread Starter
thats how i got mine. i got them from someone on here who sent me an ebay link. i dont remeber who it was because i cant find anypost or PM in my profile relating to it. the ebay seller was called high_flow_dynamics which is no longer on ebay. they were normally 300$ but were on sale for 200$ when i bought them, they also had others for chevy and big blocks so i thought it was legit. unforunatly not
from what Miller told me, one of the ways to tell is the trunnion will have a flat side on the top and bottom. mine and probably yours will only have one flat side. heres a pic of the double sided trunnion
post #9 of 46 Old 10-22-2017, 10:38 PM Thread Starter
its not that i wanted to buy cheap stuff, i knew to stay away from cheap stuff. i thought these were high quality just on a really good special. they look identical to the genuine Mid-Lift rockers, jsut half the cost. as Miller sead they are basicly the same rocker but with cheaper trunnions. this is what genuine look like.
MID-LIFT.COM ENTRY PAGE
post #10 of 46 Old 10-22-2017, 10:59 PM
Was it Paul Kane? So are the ones from Highflow not genuine miller midlift rockers?
vertvert is offline
post #11 of 46 Old 10-23-2017, 07:46 AM
TomV's Avatar
Oh crap! I probably have the same ones. How did you know they were cracked? What were the symptoms?
1989 Mustang GT
TomV is offline
post #12 of 46 Old 10-23-2017, 08:31 AM
Purchased mine right from Miller when he was having a special thank GOD
post #13 of 46 Old 10-23-2017, 09:35 AM Thread Starter
i didnt have any symptoms, i jsut noticed them when i was doing other work on the engine and pulled them off. looks like im not the only one who fell for this
post #14 of 46 Old 10-23-2017, 12:52 PM
I purchased mine from Paul Kane. I also returned them for a full refund. Can someone spell this out for me? Are the ones from Paul knockoffs?
vertvert is offline
post #15 of 46 Old 10-23-2017, 04:21 PM
Old timer
Ed Curtis's Avatar
Caveat emptor
Quote Mark O'Neal:
"Virtually every customer I have has the same first interest. That is what is the lowest price he can pay. People like myself, Ed and very few others on this board have spent decades learning what we know.....and y'all want that knowledge for free....and you'll take the parts for free as well."
Ed Curtis is offline
post #16 of 46 Old 10-23-2017, 04:33 PM
Originally Posted by Ed Curtis View Post
Caveat emptor
Hmmm...sometimes, as in my case, I purchased them before the quality and suitability were able to be determined. Paul was a stand up guy and offered a refund before I even uttered the words. This is sometimes referred to as customer service and includes return policy, answering emails, having a phone, etc. thanks for your addition to this thread, I've learned a new phrase.
vertvert is offline
post #17 of 46 Old 10-23-2017, 04:47 PM
Old timer
Ed Curtis's Avatar
Cool
Stand up guy who sells knock-off junk?
Wow....
Anyway...
Here's another word for you to learn:
customer [ˈkəstəmər] NOUN
a person or organization that buys goods or services from a store or business
synonyms: consumer buyer purchaser patron client
Nice try though... the next word you need to learn is "askhole"...
muswagon3 likes this.
Quote Mark O'Neal:
post #18 of 46 Old 10-23-2017, 05:12 PM
askhole [k-hlę] NOUN, proper
Commonly referred to as Ed Curtis
Anyhow Paul did refund my money, took phone calls, and returned messages.
Had a thread like this existed or another was easily accessible I may have known ahead of time.
Ed am I living rent free in your midget, dwarf brain? Please don't bother trying to attack me any longer. It isn't worth the calories you burn being an internet bully.
Cougar5.O likes this.
vertvert is offline
post #19 of 46 Old 10-23-2017, 05:33 PM
Old timer
Ed Curtis's Avatar
Hey troll... you quoted "my" post... Guilty conscience dweeb?
Guess you just can't handle the truth, you poor internet parasite.
Better head for your safe space little snowflake.
vertvert likes this.
Quote Mark O'Neal:
post #20 of 46 Old 10-23-2017, 05:51 PM
Oh did I hurt your feelings little guy? I'm sorry. How come you call everyone a snowflake when they don't agree with you? Isn't that one of the characteristics of a snowflake? By the way I just talked to Hillary and Obammy, they both want to buy a custom cam and spring kit with your magic dust but can't seem to get you on the phone.
Now, off to my safe place. Good night sir.
My apologies to the OP.
vertvert is offline
post #21 of 46 Old 10-23-2017, 07:03 PM
Fly off the handle much, do ya, Vert?
2 step is online now
post #22 of 46 Old 10-23-2017, 07:20 PM
SVT2785's Avatar
Trader Feedback: (27)
I have two sets of Miller Rocker arms and his shaft rocker set up. I have never had a problem with them and one set came from Paul Kane several years ago. They have the Miller trunnions. As I recall Paul was affiliated with High Flow Dynamics. But I could be wrong. If you click on the link for HFD and go to specials you will see Miller SBF Rocker Arms for sale If you look at the description they clearly note that the trunnions are not Miller.
Apparently Something Changed and Jim Miller is not able to stop it. They don't indicate that they are Xdistributors quite the contrary.
www.highflowdynamics.com/
We are a distributor of Miller Rocker Arms and are pleased to offer the 7075-T7 Aircraft Aluminum Small Block Ford rocker arms at absolute bargain pricing.
Miller SBF Roller Rockers (same manufacturer as the $3400 Miller Boss 429 hemi rocker arms)
Designed exclusively for small block Windsor motors (289, 302, 351W, etc.)
Rocker body made of 7075-T7 aircraft aluminum
8620 billet steel trunnion axle. This is a beautiful solid trunnion with a single flat, not the Miller rifle-drilled trunnion.
Beefy oversize pin on roller tip
Tiny pushrod cup oiling hole so as to help control top end oiling
Chromoly hammer-forged polylocks (ie work hardened, not broached)
Establishing proper pushrod length is a snap with the top measuring face on the rocker (instructions included).
Available in 1.6 ratio or 1.7 ratio, 7/16" or 3/8" rocker stud
Complete brand new rocker arm package with 16 rocker arms and chromoly polylocks and instructions.
Original manufacturer price was $384 Retail/$342 Racer Net
302-351W standard valve layout rockers, $298/set
N351 & Z304 0.150" offset valve rockers, $328/set
Yes, we ship international.
Questions?
You can e-mail us at:
[email protected]
Effort = Results "Roger Penske"
SVT2785 is offline
post #23 of 46 Old 10-23-2017, 07:34 PM
Nah I'm good. Just a minor personality conflict with another forum member.
vertvert is offline
post #24 of 46 Old 10-23-2017, 07:46 PM Thread Starter
so they're 'Miller' rockers without 'Miller' trunnions. my head says that makes them no longer Miller. there modified and not for the better AKA cheap knockoff
well now that i know they still sell them maybe i can get some kinda warranty for them and at least have a set of non-broken rockers i can use in my offroad truck. with mild cam and very little use, they should at least last awhile. till the engine blows up at least, its been though 4 so far. im hard on my toys lol
post #25 of 46 Old 10-23-2017, 08:01 PM
Damn, now I know why the first set of rockers I received from Paul were missing the trunion clip....
Greasy little sweaty fingers couldn't get them installed correctly.
I feel violated and dirty.
post #26 of 46 Old 10-23-2017, 08:23 PM
SVT2785's Avatar
I would't get to excited over the solid Trunnion. Crane and many other manufactures use them. Maybe you have a problem that is causing them to split? A shame to see a really nice product get trashed.
SVT2785 is offline
post #27 of 46 Old 10-23-2017, 08:57 PM
8620 billet steel steel, my irish butt. 8620 seamless cold roll...carbon steel.
And that nonsense about the double flat and the heat treat is nonsense.
tmoss likes this.
post #28 of 46 Old 10-23-2017, 08:58 PM
I don't know where these came from, but Paul has on occasion bought trunnions from me....and they aren't cheap.
post #29 of 46 Old 10-23-2017, 10:55 PM Thread Starter
well i dont know much about quality of specific parts. High Flow Dynamics and Miller are both trying to make money on thier products and they seem to use the same arm itself. Miller is selling theres for like 480$ a set and High Flow has them on special for 298$ and mention theres not using the Miller trunnions, makes me think that Miller is probably the more quality product or he is making a heck of a profit per set. for Miller to say that hes seen several of these and knew right away that they were not his from as little info as i given mean it might actually be a somewhat common on an issue.
im not sure exactly what conditions would break a trunnion in half unless there was jsut that much resistance or binding. the pushrods and guides show practuicly no wear. the valve stems and roller tips didnt have any wear. my cam is making 0.544/0.555 lift on AFR heads that should should handle plenty more lift. its on a hydrualic lifters and not seeing rpms higher than 5k. i measured the pushrods the the mid-lift procedure with IIRC turnes out to be about 0.200" longer and required longer 7/16 studs also. anything else i should check?
post #30 of 46 Old 10-23-2017, 11:06 PM
You only say that because you've never manufactured roller rockers. Making crappy ones is about the same cost as making good ones. Incidentally, there's no money in it. 99% of the buyers think they should cost 149.99.
I'd start by lookin for anything that resembles valve float. Think about the loads on the trunnion. There pretty much aren't any, other than the spring load.
post #31 of 46 Old 10-24-2017, 07:35 AM
TomV's Avatar
Kingfish999,
Are your JM Rockers designed for 3/8" or 7/16" rocker studs?
I remember when I installed mine (JM 1.7 3/8") during lash rechecking, I noticed some of the polylocks didn't seat fully on the trunnions. They seemed to wide and were hung up against the body of the rocker. The bottom edge of the polylock actually started to shear as I unthreaded them. Paul sent me a few replacement polylocks and stated someone missed the final cage bearing alignment during the last step of manufacturing. In the end, I reused the thinner polylocks from my old FMS rockers.
I'm wondering if perhaps you might have ran into the same issue. Also, have you looked into replacement trunnions yet? They don't look to hard to change with a tool that Comp sells that use can use in a bench vise.
1989 Mustang GT
TomV is offline
post #32 of 46 Old 10-24-2017, 10:15 AM Thread Starter
there 7/16 studs but the poly-locks clearn no problem as i rmeeber but ill check again. in my original pic you can see where it was seating it its pretty close to the edge. but of course there broken in half with a gap
post #33 of 46 Old 10-26-2017, 03:27 PM
tmoss's Avatar
Trader Feedback: (48)
The set of 1.7s I bought directly from Miller didn't have them either.
Tom Moss
tmoss is offline
post #34 of 46 Old 11-05-2017, 10:00 AM
I bought a set from Paul. So for a sbf, turbo'd, 400ish hp, mild lift cam. Would or should I send them back? I do have the 7/16 studs. It will be next year before the engine gets built. Opinions welcomed. Thanks ahead. My apologizes to OP if I'm hijacking your thread.
92Rustang is offline
post #35 of 46 Old 11-05-2017, 10:18 AM
indy2000's Avatar
that was answered in the second half of post#30..........
indy2000 is offline
For Sale GT40P Heads, TFS1 Cam, FMS Roller Rockers blackgt85 Windsor Engine Parts 9 09-19-2015 03:45 PM
Want To Trade Crane (Cobra) 1.7 Roller Rockers for 1.6 Roller Rockers SScott Windsor Engine Parts 3 05-27-2014 08:23 AM
For Sale Pedestal Mount Roller Rockers Gearbox94 Windsor Engine Parts 7 02-14-2014 04:52 PM
For Sale Hardland Sharp 1.6 Shaft Mount Roller Rockers 68fbjjz109 Windsor Engine Parts 6 07-08-2012 12:23 AM
For Sale 1.60 and 1.7 roller rockers with Girdle support Brent S Clay Windsor Engine Parts 2 03-30-2011 01:47 PM
